Author Topic: DANA 30 Value?  (Read 3725 times)
Rokcrwln
DANA 30 Value?
« on: July 05, 2007, 03:27:12 PM »
What would you say a DANA 30 out of a YJ with 4.56s and an ARB is worth?
Re: DANA 30 Value?
« Reply #1 on: July 05, 2007, 03:44:19 PM »
About $50....
I got dibs. :lol:
jeepheap
Re: DANA 30 Value?
« Reply #2 on: July 05, 2007, 04:18:57 PM »
$52.50  :lol:
Re: DANA 30 Value?
« Reply #3 on: July 05, 2007, 05:18:27 PM »
whats a used ARB go for, and is it less than half of a D44 axle.  If it is not save your cash and do a real up grade and get rid of the 30!  Don't forget that unless you have the same ratio in the rear then you will have to regear.
Re: DANA 30 Value?
« Reply #4 on: July 06, 2007, 12:39:40 AM »
About $500 tops, as it would ordinarily take about twice that to build the same axle with new parts.
The fact a D30 is not really a strength upgrade for anybody will likely lower that value some.
Re: DANA 30 Value?
« Reply #5 on: July 06, 2007, 01:00:15 AM »
Wow, $500 sounds a bit generous.  I'd probably only offer $350-400.
YJmechanic
Re: DANA 30 Value?
« Reply #6 on: July 06, 2007, 07:10:09 AM »
i think i'm with jeffy on this one.  you could probably sell the arb and gears easier without the axle.
Re: DANA 30 Value?
« Reply #7 on: July 06, 2007, 08:25:15 AM »
YJmechanic
Re: DANA 30 Value?
« Reply #8 on: July 06, 2007, 04:40:26 PM »
wow i didn't think it would even go that high
Re: DANA 30 Value?
« Reply #9 on: July 06, 2007, 06:05:32 PM »
Yeah so buy the axle real cheap and part it out and put your money into a real axle.
Rokcrwln
Re: DANA 30 Value?
« Reply #10 on: July 06, 2007, 08:06:19 PM »
Thanks for the input.
I'm putting a 9" in the front to match the rear and I was curious to see what I might be able to get for the D-30.  I also have the ARB and the gearset from the D-35.
If I can't find a local buyer I'll probably pull the gears and the locker out of the D-30 and sell the parts.
jeepheap
Re: DANA 30 Value?
« Reply #11 on: July 08, 2007, 06:38:15 AM »
if the locker would work in a narrow track cj 30 i'll call dibs! i been looking for a locker and 4.56 gears for my project. i'll have to look it up and see if it would work.... but keep me in mind.
Re: DANA 30 Value?
« Reply #12 on: July 08, 2007, 09:37:42 PM »
I am definitely interested in taking the arb and the gears of your hands quote me a price I cannot refuse
Art
Re: DANA 30 Value?
« Reply #13 on: July 08, 2007, 10:21:43 PM »
OK, I'll add this.  This is a Reverse Cut Dana 30.  The locker is interchangeable with all Dana 30's.  The gears are not.  The gears will only fit a YJ and some XJ's.
Re: DANA 30 Value?
« Reply #14 on: July 09, 2007, 01:06:26 AM »
I kinda figured it might be a high pinion axle,, still interested in the ARB though. Thanks for the info Jeff
