Author Topic: Opinions on Axles, Gears and Lockers  (Read 7320 times)
« on: July 18, 2007, 01:52:43 PM »
Hey, guys.  I have some opinion questions for you.
 I have a '94 2.5L YJ, and recently installed my RE 4" lift with the Advanced Adaptors SYE and Woody shaft.  THe reason I went to 4" lift is that eventually, I will change the 31" tires for 33", but before I go in that direction, I will most likely install lockers and change gear ratios.
My current intention is to go with OX Lockers (front and rear), and change the rear axle to an Alloy USA 30 spline (of course, the locker will also be 30 spline), and change the gears to 4.88 (I currently have 4.10).
My first question is, is it worth changing the axle to the Alloy USA one, or should I look for a completely new rear axle (D44?)?  I have read that the rear D35 is the weak link in the YJ, but I was wondering if the Alloy USA model is strong enough to handle the 33" tires with lockers or if it will also die on me on the long run.
The second question is, should I go with dual OX lockers, or should I use OX in the rear and something else in the front (Detroit Locker?).  What I like about the OX is that (1) the differential cover is VERY strong, it is cable operated, so an electrical or compressor (which I do not yet have!) failure will not cause a locker failure, and that while off, the Jeep will handle like stock, but I do hear they are HARD to install (the whole cable length issue).  What would be your recommendations?
Lastly, the gears.  I think 4.88 should be enough, and I should not have any issues with the current axles (I hould be able to go from 4.10 to 4.88 without much trouble), but I hear 5.13 is not necessarily compatible with my axles.  Opinions?
Anyway, this is not urgent matters, as I doubt I will do this this year (my wife is STRONGLY controlling my Jeep expenses now that she is pregnant, and to top it all off, I just paid for the lift, shaft and SYE), but I do want to start planning for this...
Felipe
Re: Opinions on Axles, Gears and Lockers
« Reply #1 on: July 18, 2007, 01:55:34 PM »
By the way, I hear front axles are strong enough for 33" and lockers; is this really so?
Felipe
« Reply #2 on: July 18, 2007, 02:16:38 PM »
D35 sucks go with a D44 or 8.8, your axles are NOT compatable with anything higher (numericaly) than 4.88, as for the front I personally dislike my D-30 but it is holing up fine with 33" and a locker (it is also what is holding me up from getting 5.38 gears) :'( , as for 4.88's and 33's they work but it can always get better and last if you can afford OX lockers get them but I would put a selectable locker in the front instead of the rear if I could only use one.  Just my oppinion but you asked :biggrin:.
« Reply #3 on: July 18, 2007, 02:59:54 PM »
I almost always recommend going with a complete axle upgrade.  If you're going to install a full-carrier locker and do shafts, then you might as well move up.  If you move up to a bigger axle you won't have to upgrade the shafts.  This is fairly inexpensive if you have a leaf springs.  Otherwise, getting the coil buckets on the axle can be expensive.
As for the OX, I'd go with an ARB.  Considering that the ARB has been around since the 70's, it's pretty straight forward.  Although the added cost of running a compressor could push it out of your budget.  The main supplier of the OX is Drivetrain Direct.  I think they might have bought OX which is why OX is still around.  As lockers go it's still new.  Getting the cables adjusted can be a pain but once set, it should be good.
I wouldn't go with a Detroit up front unless you have manual locking hubs.  The Detroit shouldn't be that big of it's not though.  Although for a daily driver you might want to be able to drive in 4wd on road without having the front understeer.  Also, if you have a vacuum disconnect up front and run a locker, the drive shaft will turn 24/7.  This can cause vibrations since the driveshaft on these modes weren't really balanced.  Also, if you put a auto-locker in the rear, there will be times when you're 1wd.  Wheel hop can be expected.
The Dana 30 on an XJ is the strongest since it's a high-pinion setup without the vacuum disconnect. (earlier XJ's sometimes have the disconnect though)  It's a toss up between a stock YJ D30 and the TJ D30.  Although, swapping the axle shafts from a XJ or TJ will make it stronger then a stock TJ D30.  The D30 can handle 33" tires.  You can even run 35's with some care.  Drive hard and you can expect broken axle shafts.
Currently I'm using a TrueTrac up front and a Detroit in the back.  When I upgrade my axles (again), I'll be going to ARB's.  It makes for a bit smoother drive onroad, especially if it's your daily ride.
« Reply #4 on: July 20, 2007, 06:42:17 PM »
OK, if I do decide to upgrade the axles, what would be the best "economical" situation (most bang for the buck)?  Anything I could pick up in the junk yard?
« Reply #5 on: July 20, 2007, 06:46:46 PM »
TJ D44 would be the easiest for a TJ.  Otherwise, just about anything will work for a YJ/XJ...
« Reply #6 on: July 21, 2007, 05:51:39 AM »
Easiest and most bang for the buck for the 2.5L would be the Ford 8.8 from a '95+ Exploder.  Plenty of axle for a YJ up to 35" or 36" tires.  Your front will hold up to 35" tires okay, 33" no problem.
I swapped in D44's front and rear, locker and gear options are more plentiful and cheaper than most all other axles.  I used an Isuzu Rodeo rear D44 and a Jeep Waggy front D44.  Both are disc brake axles and 6-lug wheel patterns.  Had to go this route so I could install 5.38 gears.  I think it was JP magazine that just did a couple articles on this very axle combo swap.
I don't have 1st hand experience with selectable lockers, but I hear far fewer complaints about the OX than I do the ARB.
« Reply #7 on: July 21, 2007, 07:29:42 AM »
Is there an option that uses the same lug pattern as my current axle?  If I am not mistaken, the rear D44 uses a different pattern, and if it does, it means I need a front axle with the same pattern, and that means new wheels, which increases the cost (right?).
« Reply #8 on: July 21, 2007, 11:48:46 AM »
Most good fab shops can redrill the axles for the smaller lug patters (this is only an option for the rear) front usually needs the larger pattern for the hubbs.
« Reply #9 on: July 21, 2007, 03:46:26 PM »
The Ford Exploder 8.8 has the same 5x4.5" lug pattern as your stock jeep axles, and nearly the same width as your rear axle.  It's as close to a bolt-in as you're likely to find.  It can also be found in many of the same gear ratios as what jeeps have from the factory, even with limited slip diffs.
Oilsmoke
« Reply #10 on: July 21, 2007, 07:04:14 PM »
I pickedup a 2001 with Disc brake with 4.10 gears Axle & install was 900 out the door. my axle was only 3/4 of an inch shorter than stock Bolt pattern 5x4.5 so stock wheels fit great. This is the Most Bang yj mod I done.
Jeffy talk me into about 4 years ago. I had a New yoke install after flange removed & Ujoint with differnet end mated to my Woody rear shaft also fit great. I'm Not sure you could do any other rearend for less money overall.
I had Mount Logan 4x4 do all the work but the Ebrake I did it becuase they where asking 125 more . I fab one for free.
jcoleman
« Reply #11 on: October 19, 2007, 09:39:56 PM »
I'm going to bring this back to life because I too have a locker question.  I'm a college student so saving money is priority #1.  I really want to do lockers but arb's and ox's are just too expensive for now.  I ran into the Auburn Gear-Ected lockers on 4wd.com and they are at the max I would spend on lockers, maybe even a little over.  The reason I like them is because they are not always engaged like a Detroit (i think that's how they work, still a bit new to this) and also when the lockers are not engaged they act as a limited slip diff.  Has anyone had any experience with these or opinions or other suggestions?
thanks
jake
jcoleman
« Reply #12 on: October 19, 2007, 09:47:35 PM »
also the locker will be for an 8.8.
« Reply #13 on: October 22, 2007, 12:02:54 PM »
I dont have experience with the ECTED, but I read (JP Magazine) that it has lots and lots of parts which could potentially fail.  Although, they use them in high HP applications, so maybe for a 4 banger they will work fine.  I do know that the most indestructible and trail proofed lockers would be the Detroit (which has bad on-road manners, includding wheel hop and clicking), the OX lockers (they are great if your cable is set up propperly; if not, they can be a pain!) and the ARB (the down side is that you need the air compressor, so budget goes up - althgouh having a compressor on-board is always an advantage!).
Felipe
« Reply #14 on: October 22, 2007, 12:07:43 PM »
If you're poor then why not just stick with a 8.8 that has a Eaton in it?  Keep in mind that a full carrier locker will need to be installed.  That means the old carrier as well as the ring gear comes out.  You'll have to shim the gear to the new carrier and may have to set up some test/cheater bearings.  Otherwise, you're looking at having a shop do the install and that can get expensive.
