Author Topic: P1687????? Urgent!!!!  (Read 956 times)
rcherb
« on: August 09, 2007, 05:54:28 PM »
Has anyone ever gotten this code combined with a p0123? I've replaced the TPS, plugs, wires, cap, and rotor. Fuel pressure is good and so are all the injectors.  Is this a sign of a bad computer? Please help, I do not want to take it to a dealership
Re: P1687????? Urgent!!!!
« Reply #1 on: August 09, 2007, 06:04:52 PM »
P1192
   Inlet Air Temp. Circuit Low
P1193
   Inlet Air Temp. Circuit High
P1195
   1/1 O2 Sensor Slow During Catalyst Monitor
P1196
   2/1 O2 Sensor Slow During Catalyst Monitor
P1197
   1/2 O2 Sensor Slow During Catalyst Monitor
P1198
   Radiator Temperature Sensor Volts Too High
P1199
   Radiator Temperature Sensor Volts Too Low
P1281
   Engine Is Cold Too Long
P1282
   Fuel Pump Relay Control Circuit
P1283
   Idle Select Signal Invalid
P1284
   Fuel Injection Pump Battery Voltage Out Of Range
P1285
   Fuel Injection Pump Controller Always On
P1286
   Accelerator Pedal Position Sensor Supply Voltage Too High
P1287
   Fuel Injection Pump Controller Supply Voltage Low
P1288
   Intake Manifold Short Runner Solenoid Circuit
P1289
   Manifold Tune Valve Solenoid Circuit
P1290
   CNG Fuel Pressure Too High
P1291
   No Temp Rise Seen From Fuel Heaters
P1292
   CNG Pressure Sensor Voltage Too High
P1293
   CNG Pressure Sensor Voltage Too Low
P1294
   Target Idle Not Reached
P1295
   No 5 Volts To TP Sensor
P1296
   No 5 Volts To MAP Sensor
P1297
   No Change in MAP From Start To Run
P1298
   Lean Operation At wide Open Throttle
P1299
   Vacuum Leak Found (IAC Fully Seated)
P1388
   Auto Shutdown (ASD) Relay Control Circuit
P1389
   No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1390
   Timing Belt Skipped One Tooth or More
P1391
   Intermittent Loss of CMP or CKP
P1398
   Mis-Fire Adapter Numerator at Limit
P1399
   Wait To Start Lamp Circuit
P1403
   No 5 Volts To EGR Sensor
P1475
   Aux. 5 Volt Output Too High
P1476
   Too Little Secondary Air
P1477
   Too Much Secondary Air
P1478
   Battery Temp Sensor Volts Out of Limit
P1479
   Transmission Fan Relay Circuit
P1480
   PCV Solenoid Valve
P1482
   Catalyst Temperature Sensor Circuit Shorted Low
P1483
   Catalyst Temperature Sensor Circuit Shorted High
P1484
   Catalytic Converter Overheat Detected
P1485
   Air Injection Solenoid Circuit
P1486
   Evap Leak Monitor Pinched Hose
P1487
   Hi Speed Rad Fan CTRL Relay Circuit
P1488
   Auxiliary 5 Volt Supply Output Too Low
P1489
   High Speed Fan CTRL Relay Circuit
P1490
   Low Speed Fan CTRL Relay Circuit
P1491
   Rad Fan Control Relay Circuit
P1492
   Battery Temperature Sensor Voltage Too High
P1493
   Battery Temperature Sensor Voltage Too Low
P1494
   Leak Detection Pump Switch or Mechanical Fault
P1495
   Leak Detection Pump Solenoid Circuit
P1496
P1498
   High speed Rad Fan Ground CTRL Rly Circuit
P1594
   Charging System Voltage Too High
P1595
   Speed Control Solenoid Circuits
P1596
   Speed Control Switch Always High
P1597
   Speed Control Switch Always Low
P1598
   A/C Pressure Sensor Volts Too High
P1599
   A/C Pressure Sensor Volts Too Low
P1602
   PCM Not Programmed
P1680
   Clutch Released Switch Circuit
P1681
   No I/P Cluster CCD/J1850 Messages Received
P1682
   Charging System Voltage Too Low
P1683
   Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit
P1684
   Battery Disconnected Within Last 50 Starts
P1685
   Skim Invalid Key
P1686
   No SKIM Bus Message Received
P1687
   No Cluster Bus Message
P1688
   Internal Fuel Injection Pump Controller Failure
P1689
   No Communication Between ECM & Injection Pump Module
P1690
   Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691
   Fuel Injection Pump Controller Calibration Failure
P1693
   DTC Detected In ECM Or PCM
P1694
   No CCD Messages Received From ECM
P1695
   No CCD/J185O Message From BCM
P1696
   PCM Failure EEPROM Write Denied
P1697
   PCM Failure SRI Mile Not Stored
P1698
   No CCD Messages Received From PCM
P1719
   Skip Shift Solenoid Circuit
P1740
   TCC Or OD Solenoid Performance
P1756
   Governor Pressure Not Equal To Target At 15–20 PSI
P1757
   Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762
   Governor Pressure Sensor Offset Improper Voltage
P1763
   Governor Pressure Sensor Voltage Too High
P1764
   Governor Pressure Sensor Voltage Too Low
P1765
   Trans 12 Volt Supply Relay Control Circuit
P1899
   Park/Neutral Position Switch Stuck In Park or In Gear
« Reply #2 on: August 10, 2007, 02:09:32 PM »
P0123  Throttle Position Sensor Voltage High
Throttle position sensor input above the maximum acceptable voltage.
Do your guages ever go dead?  Do you ever get a NO BUS message on the odometer?
