Author Topic: oil pan  (Read 2003 times)
lanulos89
oil pan
« on: August 30, 2007, 08:27:26 PM »
so after watching my oilpan deteriorate for two years, its finally started to leak hardcore all over my driveway  :brick:
so instead of throwing a stock oil pan on there, anyone know of a heavy duty tj 2.5l oil pan??????  if no then i guess ill just buy an oil pan skid, bc im not putting a new oil pan on my jeep nd having it get beat up like mine is now.
thanks in advanced
Re: oil pan
« Reply #1 on: August 30, 2007, 09:12:16 PM »
I actually have a spare with a rubber gasket. I got it in case I bash the pan on a rock. I haven't in 3 yrs. Its stock and used, but non-damaged. The biggest expense was the rubber gasket.
lanulos89
Re: oil pan
« Reply #2 on: August 30, 2007, 09:46:29 PM »
how much would u want for it, but still in all id rather go with a heavy  duty one if they make it lol, but im doubting they do
Re: oil pan
« Reply #3 on: August 31, 2007, 12:06:15 AM »
I don't think they make one.  you could either get a universal skid like the Turbo City and have it welded to the pan.  (They use adhesive which doesn't work that well.  Or else have a fabricator add some metal skids to it.
Re: oil pan
« Reply #4 on: August 31, 2007, 01:21:03 AM »
I made a skid similar to Nth Degree Mobility, without the front mounting points.  Attached only at the bellhousing to the two bottom bolts, and a small angled skid to the rear to keep from getting hung up when backing up.
