Author Topic: Old AMC 2.5 build  (Read 1901 times)
BarracudaBlueXJ
Old AMC 2.5 build
« on: September 09, 2007, 11:05:19 AM »
I have an '85 jeep cherokee with the amc 2.5 carbureted motor in it.  I just ordered a 32/36 carb for it and i would like to do some performance mods to it.  The only problem i am having is finding parts for the old motor.  Hesco's cam kits list 86 and up.  I tried putting different headers on but the intake doesn't have enough clearence for one to fit.  If any one has any ideas on what I could do to this motor for more power it would be appreciated.
Re: Old AMC 2.5 build
« Reply #1 on: September 09, 2007, 12:57:19 PM »
Most of the performance parts for any of the 2.5L's should work.  Although you have the added problem of clearing a tighter space.  Hesco is probably using '86 since I believe that was the first year for the TBI.
One of the biggest bolt-ons you can probably do is to convert your carb over to MPFI with a intake swap.  Should be good for a solid 20hp.  Although it might be easier to just drop a complete OBDI engine in there.
BTW: Performance Distributor makes a GM HEI distributor for the carb'ed 2.5L's.
BarracudaBlueXJ
« Reply #2 on: September 10, 2007, 08:48:19 AM »
thanks for the info
