Author Topic: harnesses by front grill?  (Read 3041 times)
95yj4
« on: September 09, 2007, 09:56:17 PM »
I want to know if anyone has or knows of harnesses(I call em pigtails) in between radiator and grill? theres 2 of them, one coming from each side. I'm waiting for the pics and will post when I get them.
Just wanted to know what they were for?
95yj4
Re: harnesses by front grill?
« Reply #1 on: September 09, 2007, 10:00:16 PM »
ok heres the pics
[attachment deleted by admin]
« Reply #2 on: September 10, 2007, 06:15:47 AM »
hmm looks like a tj are those for those fog lights that they put on the bumpers?
« Reply #3 on: September 10, 2007, 09:31:22 AM »
I concur those are for the Factory Fog lights.  You'd still need a switch to use them.  Although IIRC, there is no relay in the circuit.
Offline lax22
« Reply #4 on: September 10, 2007, 10:27:17 AM »
So would getting the factory fogs to work be as easy as hooking up the lights and adding a relay and switch? or is there more to it than that?
« Reply #5 on: September 10, 2007, 12:01:19 PM »
You'll want to check with a FSM to see if there is a relay for that harness.  Then it would be as simple as adding a relay, switch and lights.  If there is no relay then it would probably easier to buy a set of decent lights that come with a complete harness and use that instead.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #6 on: September 11, 2007, 05:55:17 AM »
This is actually an interesting post for me. My tj didn't come with the bumper lights and I have looked to see if I had the wires for them but I have not found them. I'll have to search a bit more today.
Offline lax22
« Reply #7 on: September 11, 2007, 07:05:44 AM »
Yeah i cant find mine either  :confused: I am going to keep looking.
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #8 on: September 11, 2007, 09:02:14 AM »
I checked my build sheet and fog lights are not on the list.  :'( I guess I'm s.o.o.l. Oh well, I can always add after markets.
95yj4
« Reply #9 on: September 12, 2007, 11:40:25 PM »
Actually now that you mention it I remember that I have an empty relay socket right by the light, next to the driver door. I should check to see if it is connected. Thx a lot.
