Author Topic: Ford 24lb injectors  (Read 1685 times)
rcherb
Ford 24lb injectors
« on: September 14, 2007, 01:52:52 PM »
Will these work in a 2000 2.5l or is it just going to cause problems?  I got them for free out of a 2001 ford 4.0l explorer.
Re: Ford 24lb injectors
« Reply #1 on: September 14, 2007, 02:15:27 PM »
You might want to check out all of the treads on the Ford Yellow 19# injectors.  I revived one older thread yesterday.
rcherb
« Reply #2 on: September 14, 2007, 07:14:17 PM »
I was reading them yesterday, I was just wondering if the 24lb injectors would work as I have received a set of them for free
« Reply #3 on: September 14, 2007, 07:34:27 PM »
Physically they will work but unless you're running forced induction, you'll probably be running rich.  Although it does help with the top end. ie., >4000rpm.  Are they Design II's or III's?
« Reply #4 on: September 16, 2007, 01:52:20 AM »
Well, I might be changing my answer.  Although its difficult getting clear cut answers anywhere.  I have to cross reference though several sources not all of them are confirmed. I will hopefully have a writeup on fuel injectors in a few days if everything goes well.
