Author Topic: How Do I Tell The Size of My U-Joints?  (Read 1895 times)
tlucier
« on: September 16, 2007, 03:19:49 PM »
Hey guys.  I've got an '01 TJ.  The previous owner installed a 6" Rought Country X-Series lift, a SYE, and a Tom Woods drive shaft.  I'd like to be a little prepared when I take it off road so I want to carry extra u-joints.  How do I tell the size of the u-joints?  Does the Tom Woods drive shaft use larger u-joints?
Thanks for your help.
Re: How Do I Tell The Size of My U-Joints?
« Reply #1 on: September 16, 2007, 03:23:50 PM »
It depends on which ones you're looking at.  Driveshaft or axle.  Driveshaft should use a 1310 while the axle uses a 297x.  I forget if TJ's use a combo U-joint like some of the later YJ's.  Those are 1310/1330's I think.  In any case Tom should know what he's talking about.
tlucier
« Reply #2 on: September 16, 2007, 03:31:31 PM »
Thanks for the info Jeff.  I plant to carry spare u-joints for both the drive shaft and the axle.  I need to get myself home if I do anything stupid on the trail.
« Reply #3 on: September 16, 2007, 05:08:23 PM »
You might want to check out the new U-joints for the 5-297x's.  They have a newer 5-760x are supposed to be stronger then the 5-297x's.  But here's the problem.  Would you rather have the weak point at the U-joint or the axle shaft?  It's probably better to make the 'fuse' at the driveshaft U-joint though.
« Reply #4 on: September 16, 2007, 06:43:47 PM »
I couldn't find the 297's when I did mine. They only carried the 760.
« Reply #5 on: September 16, 2007, 06:56:16 PM »
I believe Spicer stopped making the 297x's but you can find off brands.
