Author Topic: inertia ring size  (Read 2035 times)
rileyd
inertia ring size
« on: September 21, 2007, 11:52:58 PM »
swapping a 98 tj 2.5 into my 92 yj and I want to build an inertia ring while i'm at it. does anyone know the specs. i can obviously measure my flywheel for OD and ID , just wondering how thick to make it . seen pics on some threads looks like 3/8 " ?
Re: inertia ring size
« Reply #1 on: September 22, 2007, 12:51:11 AM »
The thickness would depend on the space between the engine block and the back of the flywheel.
The one I saw at tricounty gear in pomona ca was defenitely no thicker than 3/8 of an inch
« Reply #2 on: September 23, 2007, 03:54:32 PM »
I got one from Tri-County Gear that I have not yet installed...  You want me to measure it?
Felipe
rileyd
« Reply #3 on: September 23, 2007, 08:23:24 PM »
yes please , that would help me out a lot.Maybe you could weigh it if  possible.  I need to make mine soon so I can finish the motor swap.  I,m in Saskatchewan  and buying this here is not possible. Making my own easier than trying to order from the States.  Thanks again :beers:
« Reply #4 on: September 23, 2007, 09:20:02 PM »
Well if all else fails give these guys a call, they have them in stock.  I am pretty sure they have no problem with shipping to Canada
http://www.tricountygear.com/main.htm
« Reply #5 on: September 24, 2007, 12:57:58 AM »
Some grinding might be required to clear the block.  TCG has another company that's known for making flywheels make the inertia ring for them.
« Reply #6 on: September 24, 2007, 07:34:37 AM »
The TCG one is 9 lbs (advertised; I have not weighted it yet).  I'll get you the measurements when I get home this afternoon.  If you can, though, I do recommend them, as they were very quick and easy to order from, and the price was not that expensive.
