Author Topic: insulating/soundproofing a hardtop  (Read 2525 times)
Loke Groundrunner
« on: September 23, 2007, 03:53:38 PM »
been thinking about insulating/soundproofing the old hardtop. my plan is to get some color matched carpet and use heavy duty velcro to attach pieces fore and aft of the center roll bar. i'm hoping to cut down on a bit of road/wind/rain noise. i've noticed that recent model hardtops already come with some sort of "carpet-like" material attached. anyone got any "do-it-yerself" experience on this? cheers.
gomi
Re: insulating/soundproofing a hardtop
« Reply #1 on: September 23, 2007, 04:12:12 PM »
Here you go, curteousy of stu-offroad.com
http://stu-offroad.com/body/ht/hardtop-1.htm
Loke Groundrunner
« Reply #2 on: September 23, 2007, 05:07:15 PM »
grazie, arigato etc (although i think i'll try "extreme" velcro instead of glue first). cheers.
« Reply #3 on: September 24, 2007, 06:03:25 AM »
my dad put carpet on the inside of his hard top last year. he used some 3m spray on glue and it worked great. :thumb: the stuff comes in a rigular rattle can and is perfect for sticking carpet to stuff.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #4 on: September 24, 2007, 06:25:34 AM »
There use to be a product for the soft tops that insulated the soft tops also. I remember seeing it years ago in the back of JP magazine and others. Wish I could find it now.
j33p3r
« Reply #5 on: September 24, 2007, 09:21:46 AM »
Was it this from California Tops.
http://www.californiatops.com/liner_soft.html
gomi
« Reply #6 on: September 24, 2007, 12:15:43 PM »
Nice, but for $200 I would proably try and do it myself. That's pretty costly.
« Reply #7 on: September 24, 2007, 02:54:27 PM »
For my old YJ hardtop, I just cut a square of that foil lined foam wall insulation and set it on the rollbar before the top went on.  The weight of the top held it in place very well.  I think I used 1".
Also great for friends that think they're graffiti artists :beers:
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #8 on: September 24, 2007, 06:59:20 PM »
That may have been it. Similar concept to what I remember. I agree... $200.00 is a bit too much to pay. Seems as though it's easily replicated for much less.
« Reply #9 on: September 24, 2007, 07:01:55 PM »
I'd probably go with automotive carpet and spray-on adhesive.    If you use velcro, you'll probably have an issue with the liner/carpet sagging in areas.  In which case it would be better to mount the carpet onto a backer board.
« Last Edit: September 24, 2007, 07:04:42 PM by Jeffy »
Loke Groundrunner
« Reply #10 on: September 25, 2007, 04:52:09 PM »
yeah, I've seen that one. YIKES. $200 for a glorified blanket. i think i'll have a go at makin' one meself first. thanks anyway, though.
good idea on the backer board. i really don't muck with glue. with super-duty velcro i can at least pull it down (if i need to,...for whatever reason). thanks for the replies. i'll let you know how it turns out. cheers.
