Author Topic: Want an auto  (Read 4700 times)
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
Re: Want an auto
« Reply #15 on: October 03, 2007, 02:11:08 PM »
Yes, although I do have it wired for a computer.  I found that with the limited power band of the 2.5L that I prefered deciding where the shifts should be.
Can I mod the 3spd in my tj to do this?
Re: Want an auto
« Reply #16 on: October 03, 2007, 02:46:21 PM »
I don't believe anyone makes a manual shift body for the TF904/30RH.  I think I looked it up for someone before.
Re: Want an auto
« Reply #17 on: October 03, 2007, 04:11:52 PM »
As far as doing what I did with my AW4 - no, because there's no computer in a 904.
You would have to check with the manuafacturer to be sure, but there are a lot of 904 full manual valve bodies.  the TF904 is a common transmission used in drag cars and shares a lot of parts in common with the tf727
Here's one that might work, but I'd check with the manufacturer for an application list.
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=TC&Product_Code=121700
Offline dexetr30
  • Aloha Mr. Hand!
Re: Want an auto
« Reply #18 on: October 03, 2007, 04:40:00 PM »
Thanks Jeffy. It was probably me you looked it up for. Damn short term memory. :brick:
Quote from: oldjeep
I'll have a look at the link you provided. Thanks...
nasnop
Re: Want an auto
« Reply #19 on: October 03, 2007, 05:41:11 PM »
TF-904 is a nice transmission.
Shift kits and manual valve bodies are readily available.
The only downfall to a TF-904 behind a 2.5 Jeep is that the jump from 2nd to 3rd is a big one. I often find with steep grades that in 3rd it lugs and 2nd is revving too high.
I have 2 1995 2.5 YJs, one auto with 4.56s on 33s, one 5-speed that is stock.
The auto is an awesome rock crawler that can hang with much bigger rigs, but bogs on grades.
The 5-speed is a race car in comparison.
kenny kustom
Re: Want an auto
« Reply #20 on: October 03, 2007, 07:23:34 PM »
My supercharger will help a little.... Thats the main reason for the auto.
Re: Want an auto
« Reply #21 on: October 03, 2007, 07:49:06 PM »
Ah, cool, so there are manual valve bodies.  Now that I think I about it, I probably did see one before.   :roflol:
Offline lax22
Re: Want an auto
« Reply #22 on: October 04, 2007, 07:20:18 AM »
What ia a good price for one of these trannys? I found one on car-part.com with 25,000 miles in VA for $1000 but can they be had for cheaper? and will any year 97-2006 30RH swap in with no problems as long as i can get the flex plate and mounting plate and do i still need to upgrade the t-case from 21 to 23 spine if it comes out of another 4 cylinder jeep?
Re: Want an auto
« Reply #23 on: October 04, 2007, 10:35:36 AM »
$1000??   I wouldn't pay more than $300 and that would be if I wanted one really fast.
Offline lax22
Re: Want an auto
« Reply #24 on: October 04, 2007, 11:42:28 AM »
Ahh i am not doing that one then hahaha.
