Author Topic: quick spare tire question  (Read 6001 times)
Re: quick spare tire question
« Reply #15 on: October 24, 2007, 04:05:09 PM »
:confused: Not too sure what you mean. The gate itself is sagging ever so slightly, you can only tell when you open and close the gate. The latch catches a bit. Maybe I'll just leave it, unless it will get much worse.
As long as the tire is firmly against the tailgate bumpstops, it should get worse.  It's the vibrating that really kills the hinges.
gomi
« Reply #16 on: October 24, 2007, 05:14:29 PM »
Should? I hope you mean shouldn't :lol: The spare does press very firmly against the bumpstops, I mad sure to check. Maybe I'll just leave it.
« Reply #17 on: October 24, 2007, 05:34:48 PM »
Tomato ,Tomato...  :lol:
I've had a 34x9.5R15 on my stock tailgate for 4 years now.
« Reply #18 on: October 24, 2007, 05:48:03 PM »
maybe your best bet is to adjust the lower hinge on the bottom slide of the body loosen the bolts a bit and pull the door up a bit. I had a 31 x10.5 15" tire on my tail gate and it was fine all I had to do to make it happy was put spacers between the tire and the carrier so it was not to tight against the rubber stoppers. It should be fine hinge pins do wear so it might just be caused by wear so you can make up for it by adjusting the hinge
« Reply #19 on: October 24, 2007, 05:49:07 PM »
Doing that will exposed the unpainted parts hidden behind the hinges though.
« Reply #20 on: October 24, 2007, 05:53:58 PM »
isn't that why they sell touchup paint?
« Reply #21 on: October 24, 2007, 05:55:20 PM »
I just leave it exposed...  it adds character!   :lol:
lanulos89
« Reply #22 on: October 24, 2007, 06:13:20 PM »
the door itself didnt drop it just shifted so idk maybe im in a dream world?
gomi
« Reply #23 on: October 24, 2007, 07:07:53 PM »
now I get what you mean... :biggrin:
« Reply #24 on: October 25, 2007, 01:51:03 AM »
spacing out the rubber stop will not keep the tail gate from sagging just adjust the hinge its not that hard
« Reply #25 on: October 25, 2007, 01:53:34 AM »
Sorry for the multiple posts Fotki was having a fit
Fixed it for ya' -JJ
« Last Edit: October 25, 2007, 04:00:52 AM by Jesse-James »
