Author Topic: (Was: Jeffy's Joop) Alternator Upgrades  (Read 6262 times)
Offline dexetr30
  • 4BangerJP.comŪ Donator
  • Aloha Mr. Hand!
Re: (Was: Jeffy's Joop) Alternator Upgrades
« Reply #15 on: November 14, 2007, 07:19:05 PM »
Glad to have been of some help Jeffy.  :blbl:
« Reply #16 on: November 14, 2007, 08:36:14 PM »
Yeah, I can't drive my jeep now, LOL!   :lol:  I've got a modified 170A Alternator coming hopefully.
Re: Alternator Upgrades
« Reply #17 on: November 14, 2007, 11:14:33 PM »
I just looked at my build sheet out of curiosity....it says I have the 117 amp alternator.
Where do you guys access your build sheets?
« Reply #18 on: November 14, 2007, 11:19:24 PM »
Take your VIN to the Dealer and ask for a build sheet.
I don't need a build sheet though, I remember what I got.   :lol:  But since you have a YJ, it's either a 75a or a 90a.  You should be able to tell by getting the model number off the back of the alternator.
« Last Edit: November 14, 2007, 11:21:32 PM by Jeffy »
« Reply #19 on: November 14, 2007, 11:23:24 PM »
If I remember correctly from what I have read, it is a 90A...  I'll check once I get back to Miami (in about 20 hours!!!)
jetcracker82
« Reply #20 on: November 15, 2007, 10:13:32 AM »
I put this bad boy on a while back:
http://www.quadratec.com/products/55112_50.htm
and haven't looked back.  It says it bumps it up to 140 amps.  I haven't measured but I can run driving lights, aux lights, 400 watt amp, 10" sub, stereo, cigarette lighter, and the kitchen sink with no problems.  Just make sure you get the right one.  Don't order the one for the v belt when you need one for the serpentine belt and have to wait for forever to get the right one.  Cheers. :beer:
« Reply #21 on: November 15, 2007, 11:42:21 AM »
The thing I don't like about the mean green is that it's overpriced.  They've got their name out a long time ago and that's what you're buying.  Most starter & alternator rebuilder shops are able to bump up the amp rating of an alternator.  It's an old trick.  Put more wraps on the armature and that replace the diodes.  The only consideration is making sure it fits in the housing.  From what I've seen though 136a is one of the highest OEM alternators out there.  You can buy it new for around $150 or rebuilt for $80.  Probably costs $30 from a Pick N pull.
I ended up buying a 170A from a rebuilder on ebay for $95 with a 2 year warranty.
The pulley doesn't bother me much since I'm going to have to remove that anyway.  I have my OEM 6 groove as well as my OBA V + 6 groove.
« Reply #22 on: November 16, 2007, 08:49:59 AM »
I agree with that...  I was looking for a new alternator when I put the e-fan on, and there were sevaral on eBay that seemed good enough that i thought about getting.  But i decided to try and see if the stock unit was able to handle the load before throwing money at it, and since it has (so far, anyway!) I am sticking to that one until it bites the dust.  When I do upgrade, though, I plan to go more or less the same route as Jeffy, with a 170A one...
Felipe
