Author Topic: Brighter headlights  (Read 4427 times)
chutestrate
Brighter headlights
« on: November 26, 2007, 02:36:04 PM »
Looking for suggestions for new brighter headlights for my 2000 TJ sport.
Re: Brighter headlights
« Reply #1 on: November 26, 2007, 02:50:15 PM »
I recall reading somewhere that Hella is cheap and works well.
« Reply #2 on: November 26, 2007, 03:16:36 PM »
Sylvania Silverstars are cheap replacement seal beams.  You could step up to some H3's from IPF or Hella.  Delta also makes some too.  One problem with H3's is that they do not like moisture.  The lights aren't sealed and the bulb needs to stay dry or else it will burn out prematurely. Something to keep in mind.
Oh and there are some 'drop-in' Xenon lights but they aren't DOT legal and made from Halogen housings.
Another consideration is to install some aux. lights.  Better lights, patterns and visibility.
« Reply #3 on: November 26, 2007, 05:04:29 PM »
I used a pair of sylviana xtra vision halogen headlights and a pair of relais made a big difference in brightness and
and was not expensive the lights are about 9 bucks each at autozone and they have the relais as well. Direct battery power to the headlights definitely makes them brighter and the halogen lights give some more lights for about 30 bucks in all was not a bad investment. I am atleast very happy with it
  • Poseur Extraordinaire®
« Reply #4 on: November 26, 2007, 08:31:27 PM »
I went with IPF and Fat Boy Bulbs...they kick ass....
gomi
« Reply #5 on: November 26, 2007, 08:55:05 PM »
How much did they cost you? I was thinking about some sylvania silver stars. They are only $20 each at walmart.
spoonman
« Reply #6 on: November 27, 2007, 07:33:09 AM »
i'm really happy with my silverstars for the price. they were $20 each. cheap easy upgrade.
« Reply #7 on: November 27, 2007, 09:42:41 AM »
http://www.4wd.com/productdetails.aspx?partID=14888
$87.99   :yikes:
...but that is for a pair... :lol:
« Reply #8 on: November 27, 2007, 01:22:23 PM »
$87.99   :yikes:
OK, but then you still need to add the price of the light housings...    :wall:
« Reply #9 on: November 27, 2007, 01:51:41 PM »
$87.99   :yikes:
That was the cheap part.....2 headlight housings are cheaper than the bulbs???
http://www.4wd.com/productdetails.aspx?jeep-sid=84&plID=0&partID=12035
« Reply #10 on: November 27, 2007, 02:20:00 PM »
So $121.89 or 6 Sylvania's.  :drink:
might4banger
« Reply #11 on: November 27, 2007, 03:09:22 PM »
x whatever on the silverstars -
« Reply #12 on: November 28, 2007, 07:57:02 AM »
I have been running a couple of Delta Xenon headlights I got from Quadratec, and they are running fine...  Of course, I also added some KC Daylighters for when I get the high beams on, and some KC Slimlite Fog Lamps that I typically run whenever I got my lights on...  That REALLY improves my vision at night!
Colin
« Reply #13 on: November 29, 2007, 03:16:50 PM »
I've been thinking about doing this myself. It's actually my planned christmas present to myself, getting a better pair of headlights so that I can actually see at night.
I've been researching a few, and while cost isn't an option for safe night driving for me, I've pretty much decided on this:
http://www.quadratec.com/products/97009_120.htm
It's the Delta Xenon replacement. I'm hoping that these last me a long time basically.
A good video I searched on the differences of Xenon and Halogen can be seen here:
http://www.youtube.com/watch?v=MKjz9_BguVM
Basically I want the best front lighting that I can when I'm driving at night on the road, because it makes a world of difference. Right now a car can pull up behind me and cast a shadow over my lights they are so dim.
« Reply #14 on: November 29, 2007, 04:05:59 PM »
In case you are interested (and have access to it), JP magazine recently rated about 10 different lights for Jeeps.  You may want to take a look at it before commiting.  HAving said that, I have those lights, and I am happy with them (but then again, I have only compared them to the stock lights; I never compared it to the others that JP Magazin tested them).
I tried looking for the article online, but did not find it...  Anyway, I can dig up the article and give you the condensed results if you want.
Felipe
