Author Topic: spring creek ??  (Read 6178 times)
Grundar32
spring creek ??
« on: September 24, 2005, 07:49:24 AM »
i just put a lift on my 95 YJ and after about 3weeks i have developed a pretty good creek from the springs they are superlift and i know they arent the greatest but this is a pretty nasty sounding thing.. i was wondering if anyone else found this and what may have worked for them . i have lubed them thoughy today and hope this helps
trailblazer95
spring creek ??
« Reply #1 on: September 24, 2005, 07:58:51 AM »
leaf springs will always creak.  WD40 helps.
Grundar32
spring creek ??
« Reply #2 on: September 24, 2005, 08:12:02 AM »
i used blaster ive been pretty impressed with it's penitrating qualities
Big Whiskey
spring creek ??
« Reply #3 on: September 24, 2005, 02:20:09 PM »
PB Blaster is an awsome product, but I used a product called gel-lube on my stock spring and while it doesn't fix the problem perminently it definenatly lasted lot longer than WD or PB, It sprays on as an oil but as it set's up it turn's into a gel which seem's to stay and lubricate were you wanted it to.
spring creek ??
« Reply #4 on: September 24, 2005, 05:51:18 PM »
You also might try a dry lubricant.  Basically it sprays on wet and sticks to the surface then dries.
