Author Topic: Would a 3500lb winch work for a TJ ???  (Read 6917 times)
BOOGIE444
« on: December 04, 2007, 11:07:52 AM »
I see every one is running 8000 to 10,000lb winches on their jeeps but would a 3500lb winch get you out of some situations if your spinning your tires slowly to help?  I guess I dont understand why you need 8000lb or more for a vehicle like a TJ that only weighs around 3000lbs.
Anyways to keep a long story short would a winch like this help at all when stuck on a not so crazy trail, or would it be completly worthless?  I like that its only 23lbs as I dont want alot of weight on my jeeps front end and my 4 banger would appreciate it on all my daily driving too.  Mile marker PE3500 see linky.....
http://www.trsfabandoffroad.com/products/milemarker_atvwinches.htm
Re: Would a 3500lb winch work for a TJ ???
« Reply #1 on: December 04, 2007, 11:32:22 AM »
Pretty worthless for doing anything but dragging firewood out of the woods.
Because when you are stuck you need more than 3000LBS of force to move your vehicle.   I've gotten in situations where I stalled the 8274 on my last jeep.  I would think that 8000lb is about the minimum for vehicle recovery.
If you do decide to use a 3000lb winch, make sure you swap on some bigger cable - at least 5/16.  That 3/16" will snap like a piece of yarn with a jeep attached to it.  Personally I don't use anything but 3/8 steel for vehicle recovery.
BOOGIE444
« Reply #2 on: December 04, 2007, 12:06:10 PM »
Hmmmm.....
Is there anyway to attach a winch where you can take it on & off real easy?  I just dont want to lug around a 70lb winch on my front bumper all the time for gas mileage & handling, not to mention my front end will probably sit lower than my rear end.
Sam's club has a 10,000lb winch with wiring and winch plate for $380 here locally are they any good, I would only be using the thing a couple of times a year???
« Reply #3 on: December 04, 2007, 12:10:31 PM »
What brand is the sams club winch?  As far as an easy way to remove, not really.  They sell those reciever hitch mounted cradles, but you can't really drive around with them mounted because they kill your approach angle.
As far as having an extra 70 lbs killing your gas mileage - what happens when you have a passenger in the jeep - or a couple bags of groceries?
black99tj
« Reply #4 on: December 04, 2007, 12:40:12 PM »
Using any type of tool or machine consistantly at it's max capacity is never a good thing. They are not designed for that. The stock GVWR of a 2005 TJ is roughly 4450 lbs. Most companies and websites will tell you as a standard, you always want to have a winch that is at least capable of a load greaterthan or equal to 1.5 X vehicle weight. This is because of what was said previousely, such as being stuck in mud, or being pulled up, and over obstacles that are dragging on your vehicle creating more resistance. 1.5 X 4450 is 6675. So a 6500 lb winch is not even advised. I think you will find that unless you are pulling other things around besides vehicles, your jeep will just be used as an anchor for other small objects and won't really be able to be pulled out of bad situations with your winch.
« Reply #5 on: December 04, 2007, 12:47:13 PM »
I've driven around with and without my winch, back seat, mirrors, spare and what not.  At highway speeds, you're more at the mercy of aerodynamics then being weighed down.  I drove for a month without the stuff then added them back on.  There was no difference. So unless you're always driving at under 65 MPH you won't see any any real difference.
dunklervogel
« Reply #6 on: December 04, 2007, 03:01:34 PM »
omnisi
« Reply #7 on: December 04, 2007, 04:09:46 PM »
Another 100 bucks and you can get an 8000lb winch
http://www.shop.synergyoffroad.com/product.sc?productId=143&sourceCode=froogle
[/quot]
Is that the old ramsey?   Looks like it...
DodgeMudder
« Reply #8 on: December 04, 2007, 04:23:26 PM »
Depending on the terrain you run you can get away with the 3500lb winch, we have successfully used a 3000lb winch on the front of my buddies 4wheeler to get a Jeep unstuck a couple of times, it's not the best set-up and it doesn't give you the reassurence that you can get out of any stuck, but it will work, just carry a snatch block, and a bunch of straps as you won't have much reach with the smaller winches, but if you don't run deep mud, or hard rocks and are just looking for something to help you out when you get in some real slippery stuff it will work.
With that being said, FYI, I've stalled the 8000lb winch with a snatch block on it on my Jeep trying to get myself out of a couple stucks, and wished I had something heavier on the Jeep.
I was just thinking as typed this, my buddy has a 3500lb winch on his stock BII and it seems to work pretty good for him most of the time.
« Reply #9 on: December 05, 2007, 09:48:45 AM »
My way of thinking (mind you, this is why I DONT have a winch; I cannot afford it at this time!) is that if you are going to invest in one, get a GOOD winch...  To me, that is either Superwinch (a bit cheaper, but still reliable) or Warn (the best).
And the reason is this:
Even if you use your winch once every two or 3 years, most likely the reason you will be using it is because the S$&t hit the fan and you got stuck in the middle of nowhere.  At that point, I would much rather have the confidence that the winch will (1) work, and (2) will have enough strength to pull me out of the situation (no matter how bad) so I can get back home.  As a result, I prefer to wait and save some money, and buy me something that will bring me this peace of mind.  Until then, I will be either doing some VEEEERY light wheeling, or depending on the winch of others to get me out of tough situations...
And another comment related to this (this is kind of the advised I am not following myself, if you know what I mean): a good winch should be one of the FIRST mods to be done.  The reason for that is that all the other stuff (lift for bigger tires, bigger tires for more grond clearance, rockers, armor, more engine power, etc.) are things that will give you confdence and actually help you get stuck in the first place!
Think of the winch as an insurance...  You invest a lot of money in it, and hope you never need it.  But when you do need it, you REALLy want it to do its job!
Felipe
nic99007
« Reply #10 on: December 06, 2007, 10:56:13 AM »
Ditto,
I have found that most manufactures are a little biased in their Maximum ratings, on everything from tow straps to speakers :eek:, so for a winch to reliably and safley pull you out you will need one rated much higher than it MAX rating.
« Reply #11 on: December 06, 2007, 01:44:28 PM »
A while back I read some information on manual winches, "come alongs".  The article mentioned that many of the ratings are for pulling a load on wheels on a flat floor and not for a vertical off-the-floor lift.  The fact that vehicle winches need to be rated for twice the vehicle weight suggests that the load rating is determined in some way other than lifting a load vertically off the floor.
One thing to keep in mind is that the pull will be weaker than the rating with more layers of cable on the winch drum.
« Reply #12 on: December 06, 2007, 02:24:00 PM »
The reason why you want a winch rated for at elast 1.5x the vehicles weight is because when you're stuck, you're not dragging just the vehicles weight.  You've got to overcome whatever the vehicle is stuck in.  Imagine trying to drag a dead weight across a floor.  Now imagine trying to drag the weight over some large rocks.  Not only are you moving forward but you've also got to pull the weight over the obstical.  When you're in mud or sand you have to deal with dragging the vehicle thought it, until the ground is hard enough to ride above it.
Also something to keep in mind is that the rated pull is at the bottom roll.  Meaning you have to unwind the cable down to the last few wraps to get the fully rated pull.  Once you get to the second wrap, you reduce the pull rating of the winch.  On the third wrap, you've reduced it even more.
So if you have the bare minimum weight of the vehicle, you've got to unspool down to the bottom to get the most out of it.  This is good for another reason.  You can increase the pulling power by something like 90% by double wrapping the cable and using a pulley block.  You can do this a few times or till you run out of cable.  On larger winches, you've got to start to worry about the mount some other things.
As for a come-a-long, those are ok but will involve a lot of backbreaking work.  Tehir spools are usually small and because of that you can only pull short distances.  Then you've got to make sure the vehicle won't move them reset your position.  You've also got to have something to pull against that's near by.  There are a few heavy duty ones out there that don't have the limitations of a spool though those are expensive.  Also, a Hi-lift can be used as a come-a-long with a chain or some straps.  Although with the price of these cheap winches, even though they aren't Warns, they will be well worth the money even after one good pull.
The big three winch companies are Warn, Superwinch and Ramsey.  Overseas you'll probably see more Superwinches then Warns or Ramseys.  In the US, Warn seems to be king with Ramsey not that much behind.
DodgeMudder
« Reply #13 on: December 06, 2007, 04:25:04 PM »
Some good reading for those interested in winches.
Winches in hell
The biggest surprise to me was that the Harbor Frieght special is one of the few winches that proved it will last a hard days use.
« Reply #14 on: December 06, 2007, 04:58:35 PM »
Winches in hell
Yeah, but this makes you wonder what a second day would have brought. "It didn’t finish with the vigor it had at the beginning of the test, but it lacked the good sense to quit and survived all the Winches In Hell challenges.",  doesn't really give you that warm fuzzy feeling.  Still the CE is/was a Ramsey.  I'm not sure if you'd want to clump all of the other sub-$300 winches with it.
