Author Topic: Electric Fan conversion for the 2.5  (Read 7369 times)
vbuholzer
« on: September 27, 2005, 11:40:07 AM »
I was contemplating this mod but i haven't seen to many write ups on it. has anyone here done that and any tips about it they can share?
What i have been able to find is that the ford taurus electric fan from a early 90's 3.8 v6 should work, and possibly one from a crown vic. any advice?
Thanks!!
« Reply #1 on: September 27, 2005, 01:10:46 PM »
There are several writeup's out there.  The only concern would be to use a heavy duty relay.  Some people use the standard Bosch 30A relay but it's too small for the initial start up.  You risk burning up the relay.
trailblazer95
« Reply #2 on: September 29, 2005, 07:21:44 AM »
i'm currently working on a writeup for my Taurus fan installation that uses a PWM controller instead of relays.  So far it's been a great mod.
vbuholzer
« Reply #3 on: November 08, 2005, 02:45:52 PM »
thanks for the information.. if you finish that write up trailblazer i would love to read it.
thanks!
NiteDog
« Reply #4 on: November 09, 2005, 05:19:10 PM »
Quote from: "vbuholzer"
thanks!
Ditto!
« Reply #5 on: November 10, 2005, 08:29:36 AM »
I run a Taurus 2-speed fan, I run it on low through a switch rated for enough amps to handle low speed.  I've got everything I need to wire up both speeds through relays using a thermo switch to activate each speed, just need to get it hooked up.
You can get the fan from almost any 3.8L Taurus, Mercury, or Lincoln.  Crown Vic uses a mech. fan so don't bother looking there.  Don't get the 3.0L fan.
