Author Topic: Temp Gauge  (Read 1609 times)
enginethatcould
Temp Gauge
« on: January 08, 2008, 04:50:28 PM »
I have a '93 wrangler 2.5L, the temp gauge is not working. It hasn't been working since I put the new engine in. I changed the temp sensor and it's still not working. Is there anything else it might be before I get a new gauge?Any thoughts?
I also broke a sensor in the back of the engine. If you are underneath the hood it would be in the back on the right. Does anyone know what this is? My stupid self can't figure it out! Not really sure if this has to do with the temp or not.
Re: Temp Gauge
« Reply #1 on: January 08, 2008, 05:11:24 PM »
That 'sensor' you broke is the Temp sensor.  The one for the gauge.  The engine runs off the one on the thermostat.  The sensor should be on the head next to cylinder #4.
enginethatcould
Re: Temp Gauge
« Reply #2 on: January 08, 2008, 08:09:42 PM »
That makes a lot of sense: ) I've been to the parts store twice, and yes I'm an idiot, they told me that, that was the sensor i needed. Is there an "official name" for this sensor? I was told that it was the only sensor that ran to the gauge.
Re: Temp Gauge
« Reply #3 on: January 08, 2008, 08:35:21 PM »
I believe this is the one you need. http://www.quadratec.com/products/55122_01.htm
enginethatcould
Re: Temp Gauge
« Reply #4 on: January 09, 2008, 08:45:08 PM »
Dude......you are me new hero!
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
Re: Temp Gauge
« Reply #5 on: January 10, 2008, 06:57:52 AM »
Sorry to hijack but... can I run my ef-an off of this sensor?
Re: Temp Gauge
« Reply #6 on: January 10, 2008, 07:11:33 AM »
Nope for your e fan you need a temperature switch not a sensor. Ispro makes some or if there is room you can use one for the fan clutch of a big rig. those come on at around 185 to 190 degrees.
Offline dexetr30
  • Aloha Mr. Hand!
Re: Temp Gauge
« Reply #7 on: January 10, 2008, 11:49:35 AM »
I have a temp switch that attaches to the radiator. I guess I'll have to stick with that for now. I was just looking for something that would look more stock.
Thanks for the reply.
