Author Topic: 2.5L to TF999  (Read 4821 times)
Re: 2.5L to TF999
« Reply #15 on: January 28, 2008, 12:57:30 PM »
It should bolt up, just need to change the input shaft. Did they not all use the same bolt pattern ?
Are you talking about the transmission or the transfercase now?
What did the TF999 come out of?  If it came out of a 4.2L YJ then it has the wrong bellhousing to bolt to a 2.%L
kenny kustom
Re: 2.5L to TF999
« Reply #16 on: January 28, 2008, 01:04:46 PM »
Tranny. Did the 6 and the 4 not share the same bellhousing ?
Re: 2.5L to TF999
« Reply #17 on: January 28, 2008, 01:08:19 PM »
Nope, never have.
kenny kustom
Re: 2.5L to TF999
« Reply #18 on: January 28, 2008, 01:19:19 PM »
So did you use a dakota housing or what ?
Re: 2.5L to TF999
« Reply #19 on: January 28, 2008, 01:28:00 PM »
I'm getting pretty confused, but here's a shot.
I had a 2.5L Comanche.
I used a TF999 from a 2.5L Cherokee
A TF999 does not have a removable bellhousing, the trans has to match the engine.
On my YJ I have a 2.5L
I used an AW4 from a 2.5L Cherokee
kenny kustom
Re: 2.5L to TF999
« Reply #20 on: January 28, 2008, 01:36:40 PM »
I see. I was under the impression you used an aw4 from a 4.0L . Hmmm. I might have to make an adapter plate for it if i want to use this transmission.
Re: 2.5L to TF999
« Reply #21 on: January 28, 2008, 01:43:36 PM »
I thought it was the TF904 (3Speed)?
Sorry, I was confused for a sec. The 909 and the 904 were the same minus the converter.
« Last Edit: January 28, 2008, 01:49:44 PM by Jesse-James »
Re: 2.5L to TF999
« Reply #22 on: January 28, 2008, 04:05:26 PM »
AW4 has a removable bellhousing, so you can use any AW4 as long as you have the correct bellhousing for your application.
999's are a dime a dozen, not worth the effort to try to adapt a 4.2/4.0 999 to work with a 2.5
Re: 2.5L to TF999
« Reply #23 on: January 28, 2008, 04:08:31 PM »
The AMC I6's use a different pattern then the 2.5L's for the bellhousing.
kenny kustom
Re: 2.5L to TF999
« Reply #24 on: January 29, 2008, 10:50:49 AM »
Fine.. I see i have been beat. If i cant mate the tranny to the motor, i might as well just swap out the motor. I have sold my blower, so i think its time for a 360. THEN, i can use the 999......
