Author Topic: 2.5L to TF999  (Read 4820 times)
kenny kustom
2.5L to TF999
« on: January 27, 2008, 01:47:15 PM »
Whats needed with regards to input and output shafts ? Anyone done this swap ?
Re: 2.5L to TF999
« Reply #1 on: January 27, 2008, 03:22:16 PM »
Input and output shafts of what?   I swapped a 999 into a 2.5L comanche a few years ago, all you had to do was remove the pilot bearing from the crank, swap the flywheel for a flexplate and adjust the driveshaft lengths.
Re: 2.5L to TF999
« Reply #2 on: January 27, 2008, 06:32:27 PM »
Are you switching from the 5spd to the 999?  If the 999 is compatible with the 2.5L, you have to change the transfer case input from short 21spl to long 23spline.
kenny kustom
Re: 2.5L to TF999
« Reply #3 on: January 27, 2008, 06:58:10 PM »
what about the input to the tranny from the engine ? same as the ax5 ?
kenny kustom
Re: 2.5L to TF999
« Reply #4 on: January 27, 2008, 06:59:53 PM »
i am removing the ax5 and putting in the 999
Re: 2.5L to TF999
« Reply #5 on: January 27, 2008, 08:24:55 PM »
Input from tranny to engine?
kenny kustom
Re: 2.5L to TF999
« Reply #6 on: January 27, 2008, 08:25:32 PM »
tranny to engine shaft.
Re: 2.5L to TF999
« Reply #7 on: January 28, 2008, 02:44:50 AM »
I'm not familiar with the 999 tranny, but if it was commonly available behind the 2.5L you'll likely just have to put in the appropriate pilot bushing.
Re: 2.5L to TF999
« Reply #8 on: January 28, 2008, 10:40:07 AM »
The TF999 was the auto found behind the 4.0L
Re: 2.5L to TF999
« Reply #9 on: January 28, 2008, 11:36:28 AM »
Good luck with that.
RoKnAzn
Re: 2.5L to TF999
« Reply #10 on: January 28, 2008, 11:39:35 AM »
I thought it was the TF904 (3Speed)?
kenny kustom
Re: 2.5L to TF999
« Reply #11 on: January 28, 2008, 11:48:07 AM »
This came out of a 87 with the 4.2l
Re: 2.5L to TF999
« Reply #12 on: January 28, 2008, 12:27:25 PM »
TF999 was also used behind the 2.5L in some cherokees and comanches
Re: 2.5L to TF999
« Reply #13 on: January 28, 2008, 12:29:32 PM »
YJ from 1987-1991 with the 2.5L and 4.2L engine, and in the XJ in 1991 with the 2.5L engine.
If was originally behind a 4.2L then it isn't going to fit on a 2.5L.   You need one that was behind a 2.5L
kenny kustom
Re: 2.5L to TF999
« Reply #14 on: January 28, 2008, 12:31:33 PM »
It should bolt up, just need to change the input shaft. Did they not all use the same bolt pattern ?
