Author Topic: Snorkel on a 2.5L  (Read 20749 times)
joe-joe
Snorkel on a 2.5L
« on: October 14, 2005, 09:35:07 AM »
Just wanted to know if anyone has run the Jeep TJ 4.0 Snorkel on their 2.5 since they don't make one for us?
Snorkel on a 2.5L
« Reply #1 on: October 14, 2005, 01:32:58 PM »
I don't think it would be that hard to modify the kit to work.  The kit probably uses the OEM airbox and retains the stock system.  I know for sure this is how they do ti on the YJ and a few other apps.  ARB retains the stock box so all the emission lines aren't disturbed and doesn't have to get a CARB number for CA.
Some people get rid of their airbox and run the flex hose to the pledium on the TB.  You'd have to figure out a way to retain the CCV and Charcoal canister return though.
jeepboy21
Snorkel on a 2.5L
« Reply #2 on: October 27, 2005, 04:18:46 PM »
i have on my YJ bolted right up. the hardest part was making that big of a hole in my fender.
Snorkel on a 2.5L
« Reply #3 on: October 27, 2005, 04:39:49 PM »
Quote from: "jeepboy21"
That's the easy part!   :wink:  :lol:
Grundar32
Snorkel on a 2.5L
« Reply #4 on: October 27, 2005, 07:54:39 PM »
ive seen it done .. a guy at the jeep rally i went to in somers CT had the tj one hooked up .. and he was running a supercharger on it too .. was kinda cool to see... i like the snorkle look on the pass side too
Snorkel on a 2.5L
« Reply #5 on: October 27, 2005, 08:52:58 PM »
I prefer it on the driver side since it's closer to the intake and stays away from the engine as much as possable.  I've thought about doing a snorkel although probably not an ARB.  I like some of the DIY's that can be removed when not needed.
Grundar32
Snorkel on a 2.5L
« Reply #6 on: October 27, 2005, 09:10:40 PM »
guess i should have mentioned due to the way he had the supercharger set up the intake was on the pass side anyway .. it does make more sense to have it on drivers but i just dont like the way it sits
never heard of a DYI ? whats that ?
Snorkel on a 2.5L
« Reply #7 on: October 27, 2005, 09:28:41 PM »
DIY  = Do It Yourself
Craigs_YJ
Snorkel on a 2.5L
« Reply #8 on: October 27, 2005, 11:00:29 PM »
Not my build, but a member of our jeep jamboree trailguides writeup on making it yourself.
http://www.bc4x4.com/tech/2005/snorkel/
Snorkel on a 2.5L
« Reply #9 on: October 27, 2005, 11:32:16 PM »
I like it except for the huge metal pipe.  I'd probably go ABS.  I do like how it goes through the hood like the old snorkel kits for military Jeeps.
01amberfirewv
Snorkel on a 2.5L
« Reply #10 on: October 28, 2005, 06:55:13 AM »
Looks like a good project, I guess the humidifier top would help keep water out.  I have always thought that it is a little more risky to have a giant rain catcher at the end of you snorkel than having a hole that is 3ft above the ground.  I have heard that ARB has done some things to prevent rain from entering the system but havent figured out what yet.
trailblazer95
Snorkel on a 2.5L
« Reply #11 on: October 28, 2005, 07:26:11 AM »
the way ARB designed the top unit it now has molded ridges to help guide the rain out.  It explains it on their site.   I honestly don't see where the moisture would become a problem, every jeep brings moisture into the intake, but it's vaporized before it gets to the engine.  you'd be amazed at steam's cleaning ability in the engine.
plus, have you ever heard of "water injection"?  It's where a small sprayer of water is added to the intake, to keep the engine air temperatures lower.  it's sprayed as a fine mist, which cools the air.  it's been used for probably the last 20 years with positive effects, and it's even been outlawed in various racing circuits due to the unfair advantage it offers in engine performance.  ever notice how your jeep runs better in the cold weather than the heat?   from a performance standpoint, a snorkel does bring in cooler air, which is a plus.
but if you're looking at it from the true offroad perspective,  it becomes another part hanging off your jeep.  i've seen them ripped off, crushed, and even broken in half.  you'll have to work harder to try and avoid damage to it.   as far as water fording, if you're going in water deeper than your factory airbox, i'd say you have bigger problems.
Snorkel on a 2.5L
« Reply #12 on: October 28, 2005, 12:58:30 PM »
Well snorkels are not just used for water crossing but also really dusty area's.  They are very popular in the outback because of this.  But I won't be spending $300 for something that can be crushed or broken when I can spend much less and get the same results.  That's one of the reason's I'd want it to be able to break down.
jwrape
Snorkel on a 2.5L
« Reply #13 on: November 04, 2005, 07:09:15 AM »
With the snorkel facing forward would this give a ram air affect? Would your performance and mielage be affected? Hopefully in a good way...?
trailblazer95
Snorkel on a 2.5L
« Reply #14 on: November 04, 2005, 09:21:11 AM »
wouldn't count on much of an increase at all.
