Author Topic: Looking for a part?  (Read 1414 times)
Looking for a part?
« on: April 01, 2008, 08:51:10 AM »
A couple years ago I put a 1" body lift on my TJ.  The only thing that the lift didn't come with was two 1" spacers for the rubber stops on the front of the body.  Not the center one that support the tub but the two on each side that rest on the frame.  I don't know if this is even important but it does allow my tub to move a little bit. Is there an easy and cheap fix for this?
Re: Looking for a part?
« Reply #1 on: April 01, 2008, 12:18:33 PM »
Use some 1x1 box tubing.  Then drill a hole through two walls.  Feed a screw into one side bolt the bushing to it.  Then screw the whole thing to the grill.
