Author Topic: 97-06 Rubicon Rims fit what tires?  (Read 2429 times)
bigchelis
« on: April 03, 2008, 05:50:14 PM »
I see a whole lot of 06 and 05 Rubicon rims for sale.  I like the fact that they are aluminum and the look.
I want to be able to fit 33x12.5x16 A/T
I think the rims are 16x8 and not sure if these tires sizes will fit.  I sure hope so.
anyone know if it will?
Re: 97-06 Rubicon Rims fit what tires?
« Reply #1 on: April 03, 2008, 06:05:46 PM »
Common swap for other Jeeps.  I too like the wheels.  The stock tires are overkill though.  They have a E Load rating.  Put your own choice of tire on there though and you'll be fine.
bigchelis
« Reply #2 on: April 03, 2008, 06:41:25 PM »
any 33's will fit
« Reply #3 on: April 07, 2008, 02:09:27 PM »
Rubicon wheels are 16" diameter wheels. Only tires designed for the 16" diameter wheel will work. Also, the width is probably a 7 or 8". Many tires are designed to work in those perameters. Some 'wide' tires will need a wider rim to fit well.
« Reply #4 on: April 07, 2008, 06:22:02 PM »
They're 16x8's.
bigchelis
« Reply #5 on: April 07, 2008, 06:32:48 PM »
I was thinking of putting 33x12.5x16 on them
I currently have 33x10.5x15 and they look too thin.
« Reply #6 on: April 07, 2008, 06:45:15 PM »
You will most likely end up with a bit of tire rub with the 12.5 width.
Offline Elyod
  • Sedona is red
« Reply #7 on: April 08, 2008, 03:54:06 PM »
I remember reading somewhere, most likely this site, that a good rule of thumb is that the widest tire you can fit on a wheel should be 50% wider than the wheel.  That means that on an 8" rim you can fit a 12" tire.  so 12.5 should be fine.  also, youmight want to check out 285/75/16 for a tire size.  these tires are about an inch taller than a 33" and about an inch narrower.
bigchelis
« Reply #8 on: April 08, 2008, 05:03:11 PM »
Thanks,
If this is true this might be a better option.
