Author Topic: serpentine belt switcheroo?  (Read 1830 times)
jcoleman
« on: April 13, 2008, 11:07:37 PM »
well I have an air conditioned tj and of course the ac doesn't work.  I was wondering if I could take off the air conditioner unit and switch the serpentine belt out for one without air conditioning.  I remembered seeing some diagrams in one of the service manuals and they looked basically the same except one had the AC unit, and the other did not.  I can't find that diagram anymore because the links for the 98tj factory service manuals no longer work
anywho just a thought to get rid of some weight and a negligible amount of friction.
jake
Re: serpentine belt switcheroo?
« Reply #1 on: April 14, 2008, 07:59:27 AM »
You can always keep the belt as it is, and find a York compressor in a Junk Yard, for OB Air...  I mean, since you have accepted the fat that you will not have AC, why not use the space your current compressor is taking up...
« Reply #2 on: April 14, 2008, 08:03:41 AM »
The AC compresor itself can be used for on-board air, that is if the compresor still works in your case (or get another used one).
« Reply #3 on: April 14, 2008, 09:01:56 AM »
I assumed the compressor was the reason for the AC not working...  If it is not, you can use the same one.
jcoleman
« Reply #4 on: April 14, 2008, 12:26:38 PM »
oh, that sounds like a good idea! Thanks, I'll look into it.  :clap:
« Last Edit: April 14, 2008, 12:32:45 PM by jcoleman »
