Author Topic: new noise - clutch, t/o bearing or tranny?  (Read 1623 times)
gkainz
« on: May 06, 2008, 09:57:54 PM »
kids' 95 YJ, 150k miles, AX5 manual tranny  - started making a new noise, sounds like a "sandpaper" shhhhhhhh or dry bearing when in neutral with the clutch out.  Disappears completely with the clutch pedal about half way down, comes back just a little when completely disengaged.  The clutch doesn't seem to slip, even though two boys learned to drive a manual in it.
In trying to guess how long to kick the wife's car out of the garage for this, I'm wondering if this just sounds like a clutch (new one going in, anyway), throwout bearing (ditto on new one) or if I'm looking at bearing(s) in the tranny.  If it's a tranny rebuild, then I'm going to have to negotiate better with the wife!
Oh yeah, drained and filled the tranny with new GL-5 gear oil - no change.  I intend to change that out with Redline after the clutch job.
Thanks
Greg
« Last Edit: May 07, 2008, 01:44:06 AM by Jesse-James »
gkainz
Re: new noise - clutch, t/o bearing or tranny?
« Reply #1 on: May 06, 2008, 09:59:26 PM »
title should have said "t/o bearing" not "t/b bearing" ... darn glasses!  Is there also an Edit Post feature that I'm too blind to see?
Greg
Fixed it for ya' -JJ
« Last Edit: May 07, 2008, 01:44:55 AM by Jesse-James »
  • Poseur ExtraordinaireŽ
« Reply #2 on: May 07, 2008, 08:52:07 AM »
FYI...you need to be a member a little longer and have more posts to be able to edit.  :thumb:
« Reply #3 on: May 07, 2008, 11:18:12 AM »
You have to wait something like 30 seconds before you can edit your post then you have up to 15 minutes.
gkainz
« Reply #4 on: May 30, 2008, 10:18:38 PM »
it was the throwout bearing ... almost back together again with new clutch kit installed ... waiting on 2 new nutserts in order to put the skid plate back on.
