Author Topic: Goodies I Should Take?  (Read 1500 times)
Dan Marino
« on: May 12, 2008, 02:26:29 PM »
Guys,
Here's a follow-up to my previous post.  My brother in law is trashing his 1990 2.5 engine and manual transmission.  He's installing a GM V-6 engine and transmission.  Is there anything I should grab from him that I might be able to use on my 1994 2.5?
Thanks for the help.
Tom
Re: Goodies I Should Take?
« Reply #1 on: May 12, 2008, 04:10:24 PM »
Guys,
Tom
Not really, unless you want a spare block and head.  None of the accessories will transfer over other then maybe the water pump.  The rest is all stuff you don't really need since you have a MPFI.
« Reply #2 on: May 13, 2008, 08:30:16 AM »
Before you take things off, make sure they will at least work on your Jeep.
Grab the lower alternator mount. They will tend to crack and break, then take out the alternator shaft.
If it has AC, grab the setup also to include the compressor, condensor, mount on engine, etc. Most engine swaps the owner will keep the evaporator in the dash and just disconnect the tubing to it. The condensor could be used as an auto trans cooler if you have an auto, or someone like me. The compressor and the mount could be used for OBA setup, but this will require an oil separator since the compressor freon is lubricated.
Radiator, many swaps will require a different radiator. The shroud and fan you could keep just for the point in time where you wheel too deep in water mud and the fan bends and takes out the shroud.
Working condition starter and alternator are good things to keep around.
