Author Topic: Difficulty involve in newer 2.5 engine replacement for 88 h block 2.5  (Read 2033 times)
dynamo
How hard is it to convert a newer 2.5 engine into a 88 Jeep Wrangler, I would prefer to have upgraded hardened valve seats, There are a few engines available locally way cheaper than rebuilding mine.
If you reuse your intake & exhaust manifolds, as well as the TBI, it's pretty much drop in.  It's when you do a proper swap to MPFI that it becomes more involved.  You'll be either upgrading to OBD I or OBD II which has a lot of baggage.  OBD II more so.
dynamo
Thank you very much , I've inherited my son's broken stalled project and I'm am a newbie Jeep fixer.
Re: Difficulty involve in newer 2.5 engine replacement for 88 h block 2.5
« Reply #3 on: September 05, 2010, 11:44:33 AM »
Jeffy, you're saying I can use the '94 block and head in my '89?
« Reply #4 on: September 05, 2010, 11:52:20 AM »
the blocks are identical, only internals and the head has changed but i think you can still bolt on the intake and exhaust. Oil pan could be different and the oil pump in your case (between comanche and wrangler) so you might want to research that as if i remember correctly the gaskets are also different.
« Last Edit: September 05, 2010, 11:52:41 AM by sharpxmen »
