Author Topic: Installing a Rubicon Express 3.5 lift  (Read 15190 times)
Re: Installing a Rubicon Express 3.5 lift
« Reply #15 on: June 25, 2008, 11:32:14 PM »
36mm IIRC
Bill M.
« Reply #16 on: June 25, 2008, 11:52:08 PM »
36mm IIRC
IIRC?....I've read a DPA will fudge up my stuff and its not nessicary with the 3.5.... what is your expert opinion???
Offline aw12345
    • my jeep picture page
« Reply #17 on: June 26, 2008, 06:04:18 AM »
Doesn't need it, that's why the Rubicon express kit doesn't come with one
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
Bill M.
« Reply #18 on: June 26, 2008, 11:08:50 PM »
I am so pissed.....I got the front end completly done, got the rear shocks, off, then the coils... and then I had to remove the rear track bar bracket to replace it with the new one... and I couldnt get the bolt off... it was rusted in... me and my buddy tried as hard as possible to get it off...but no go...After everything... so close.... but no.. one bolt to hold me back... So what I am going to have to do is drop the fuel tank... and drill out the bolt... I doused it with some rust remover....so I'll give it one more go in the morning... anyone have any suggestions??  :crap:
« Reply #19 on: June 27, 2008, 12:14:45 AM »
That's how things usually go.  Everything runs smoothly till something screws it up.  It's usually something small, too.  I'd soak it over night then soak it again in the morning then you might try hitting it.  Vibrations might help loosen the rust.  Then try to remove it.  Air tools would make short work of it.  It would either remove the bolt or break the head off.  In either case it would be off.   :lol:
Bill M.
« Reply #20 on: June 27, 2008, 12:30:51 AM »
Yea... I might try that.. The only problem is that my fuel tank is in the way.. how hard is it to drop it?????
« Reply #21 on: June 27, 2008, 07:27:20 AM »
One method that has never failed me is to heat the bolt or nut with a torch and then cool it off with BP Blaster applied to the threads.  This is usually after applying BP Blaster a few times before without heat with no luck.
mgramann
« Reply #22 on: June 27, 2008, 07:34:20 AM »
I agree with the heat method, assuming you aren't too close to the gas tank.  I've gotten many bolts loose by heating until red then quickly taking the breaker bar to it.
Bill M.
« Reply #23 on: June 27, 2008, 08:00:56 PM »
Well after much fustration.. I called my dads friend who works with him as a special forces mechanic...*he didnt go to iraq with my dad* and well, long story short, he busted it loose in about 10 minutes... lol... so now it looks like I am back on schedual for the lift being done tomorrow!!! :doggy: :doggy: :dance: :dance: :beers: I am soooo happy!
willbacker45
« Reply #24 on: July 14, 2008, 10:27:09 PM »
did u get it done we need pics  :naughty:
Bill M.
« Reply #25 on: July 15, 2008, 04:39:49 PM »
Sure did! I is under the Posuer Central thread called After the lift!
http://4bangerjp.com/forums/index.php?topic=4891.0
Offline smashcoast
« Reply #26 on: July 16, 2008, 05:50:52 AM »
Hey, aw12345 is that the hills above the cajon pass?
chrisjsmith4
« Reply #27 on: May 18, 2010, 10:43:55 PM »
I am going to do this kit as well. I went to a 4wd shop and they recommended the sye kit as well and they also said to get a rubicon driveline. Is this needed. It adds another 500 to my budget that isn't in the budget.
« Reply #28 on: May 18, 2010, 11:23:58 PM »
what's a rubicon driveline? if you do the SYE you'll need a new rear driveshaft, you can get away with a t-case drop though if you're on a budget and you won't need a driveshaft.
chrisjsmith4
« Reply #29 on: May 19, 2010, 01:32:17 PM »
How do I lower the transfer case? is that just the spacers on the tranny skid? Id like to get the lift for the summer. Ill order it when the jeep is getting tuned. i meant driveshaft
