Author Topic: to buy or not to buy?  (Read 1914 times)
willbacker45
« on: June 29, 2008, 10:31:53 PM »
 :confused: i found this on craigslist and was onderening what you guys thought should i buy this or no?
Full Traction Jeep TJ 3" lift kit
Includes front & rear springs, adjustable front track bar, rear track bar bracket, bump stop extensions, tc-case drop spacers, 5100 series hydraulic shocks, hardware. This kit is new and was never installed. Asking $350 or make offer
is this all i need or what else do i need to install this?
thanks for the help
Bill M.
Re: to buy or not to buy?
« Reply #1 on: June 29, 2008, 11:35:57 PM »
Well I just dropped over $1000 on my Rubicon Express Lift, which was 3.5 inches....so I'd say buy it. The adjustable track bar alone is about $200...so this is a great deal... Just make sure that it comes with all the mounting hardware and that there is no damage or rust on any of the components...
The install wasn't that bad. It took me 4 evenings of about 2 or 3 hours each evening to do. All you need is a set of metric and standard wrenches and sockets, an air drill, spring compressors *which you can rent at autozone for free...just pay a deposit and then when you bring them back you can get your money back*, a T-55 TORX bit, and a tie rod puller, which is the same deal as the spring compressors. This is a great write up on installing the kit. Just skip the parts about the control arms. http://www.4x4xplor.com/RE-SuperFlex.html
One thing you will have to buy is extended brake lines. Sure, you can run the stock ones, but you run the risk of busting them loose when you flex.
« Reply #2 on: June 30, 2008, 12:31:30 AM »
You don't need to buy extended brakehoses just drop the hardlines down on the frame about 1" or so and it will be fine
Bill M.
« Reply #3 on: June 30, 2008, 01:44:32 PM »
True...lol... but I like the look of my new steel line covers....so eh... lol :blbl:
« Reply #4 on: June 30, 2008, 01:55:28 PM »
Another option is to use some YJ brake lines.  They are about 4-6" longer IIRC.
