Author Topic: throttle body/Intake question  (Read 2851 times)
blacknblue
« on: July 11, 2008, 07:59:34 PM »
So I am shopping around for a 4.0 throttle body to swap in.  I have also been checking out cold air intakes.  Most of the quality ones...K&N, Volant only have applications for the 4.0.  I run a Banks header (torque tubes) and a Banks Monster exhaust.  Banks makes a ram-air cold air intake for the 4.0.  Here is my million dollar question..."If I were to swap in a 4.0 tb then would a cold air intake designed for a 4.0 work?" :confused:  Or would I need an intake designed for a 2.5?  Are they designed based on the size of the throttle body or the location?
Re: throttle body/Intake question
« Reply #1 on: July 11, 2008, 08:10:19 PM »
No, it has nothing to do with the TB but rather the placement of the TB.  The 4.0L has the TB further forward so it will be short for a 2.5L.
Offline VA_YJ
  • Now I need a CJ...
« Reply #2 on: July 14, 2008, 02:30:15 PM »
I am running an AEM Bruteforce CAI with a 4.0 throttle body on my 2.5 liter engine.  Works real well.  The dryflow element does not require oiling.
GeorgiaYJguy
« Reply #3 on: July 14, 2008, 03:03:02 PM »
So all yall running a 4.0 tb on an 2.5 Is that like a 91 and up 2.5. ? Just dont look rite on my 89
« Reply #4 on: July 14, 2008, 03:55:14 PM »
Might want to peruse the FAQ.
http://4bangerjp.com/forums/index.php?topic=8.0
blacknblue
« Reply #5 on: July 15, 2008, 04:26:53 PM »
Thanks for the help Jeffy.  I will probably run the 4.0 t/b with my stock intake and establish a baseline for the CAI mod later on.   Here is a link to JP magazine... they did a cold air intake shoot out on a dyno and compare 4-5 of the top intakes.  http://www.jpmagazine.com/techarticles/engine/154_0804_jeep_wrangler_intake_shootout/index.html      :thumbsup:
blacknblue
« Reply #6 on: July 15, 2008, 04:29:03 PM »
Sorry... actually the review is for 10 of the top cold air intakes.
« Reply #7 on: July 16, 2008, 12:06:05 PM »
Consider a 62mm throttle body, 7mm larger than the 4.0 tb and removes the taper for quicker off-idle throttle response.  Check out the classifieds.
blacknblue
« Reply #8 on: July 16, 2008, 04:24:37 PM »
I was considering the 62mm... I will look into it...thanks Bounty Hunter.
