Author Topic: high oil gauge reading??? Maybe a bad sending unit?  (Read 1456 times)
nofearblackstar
« on: August 06, 2008, 01:03:28 PM »
The other day i noticed an extreamly high oil reading . When i start the jeep i goes up till it tacks out very fast then drops to about 20-30 . Then when its warmed up it drives around at about 70 but when i put in the clutch and pull it out of gear it tacks out real fast then drops down to idleing range again
And when i say it tacks fast i mean fast . Almost like a messed up gauge or something ? I dont know anything about gauges or how the oil ones work so ....
Also its a 93 yj with a 4 cl , Changed the oil about 500 miles ago
Also it runns great i notice nothing changeing in the engine no matter what the gauge is doing
Thanks
Alex
Re: high oil gauge reading??? Maybe a bad sending unit?
« Reply #1 on: August 06, 2008, 06:45:00 PM »
Change the oil pressure sender.  It's on the distributor side of the engine block, just in front of it.  Looks like a brass cylinder with one wire going to it.  When mine went out, it would peg with anything over idle.  ???
nofearblackstar
« Reply #2 on: August 06, 2008, 07:16:34 PM »
Thats what i was kinda thinking just wasnt sure . ill go get one and see what it does
