Author Topic: Backspacing question  (Read 2075 times)
crtjse
« on: August 11, 2008, 10:38:35 AM »
I am planning on getting a 2.25" BB with 32X11.15 BFG AT's on pro comp series 97 15x8's on my 04 TJ SE. I was wondering whats the maximum backspacing i could get without any rubbing? I was planning on going with 3.75, but from what ive heard, the wheels would stick out too far and look bad.
Re: Backspacing question
« Reply #1 on: August 11, 2008, 11:32:40 AM »
I'd go with something in the 4.75"-4.25" range.  You may still need to shim the steering stops but you won't miss the difference. 3.75" is the norm for those running 35's and up.
crtjse
« Reply #2 on: August 11, 2008, 11:41:03 AM »
what do you mean by shim the steering stops?
« Reply #3 on: August 11, 2008, 11:48:30 AM »
The steering stops are what set your steering limits.
crtjse
« Reply #4 on: August 11, 2008, 02:18:20 PM »
Gotcha, but what do you mean by shimming them?
« Reply #5 on: August 11, 2008, 02:58:35 PM »
Adding shims/washers to adjust the stops.  http://4bangerjp.com/forums/index.php?topic=2697.0
« Last Edit: August 11, 2008, 03:00:05 PM by Jeffy »
crtjse
« Reply #6 on: August 11, 2008, 03:15:00 PM »
Thanks so much for your help, I think I'm going with 4.25"
