Author Topic: Dana 44 question  (Read 8014 times)
95yjman
Dana 44 question
« on: August 20, 2008, 06:49:35 PM »
I'm sure this has been brought up before so I hope I don't get flamed for this heh.  So a 44 out of a cherokee would swap in pretty easy to a YJ? How about a 44 out of a wagoneer or some full size Jeep?  What would be the best year to get a 44 out of wagoneer for a YJ?
oldirtydirt
Re: Dana 44 question
« Reply #1 on: August 20, 2008, 10:19:31 PM »
i got my front dana 44 out of a 85 grand wagoneer and it is almost the same width with disk and a driver side drop......P III
« Reply #2 on: August 21, 2008, 12:52:43 PM »
Easy?  Nothings easy.  Well, maybe if you checked the FAQ.  ;)
http://4bangerjp.com/forums/index.php?topic=474
Now, are you looking to replace BOTH axles or just one?  If it's just the rear then you will have to go with a 1987-1991 Grand Wagoneer.  Anything else won't have the correct rear differential.  If you want BOTH axles then you'll can get both from those year as well mixing and matching a '80-'91 front axle.
Also, keep in mind that the SJ Dana 44's have a 6 on 5.5" bolt pattern.
95yjman
« Reply #3 on: August 22, 2008, 01:19:35 PM »
Thanks man, second time you got me with the FAQ  8)  Right now I'm looking to just get rid of the 35.  My Dana 30 is HP and I plan to do away with the vaccum disco by installing a TJ shaft.
« Reply #4 on: August 22, 2008, 03:13:05 PM »
You might consider a Explorer 8.8" as well.  They are 5 on 4.5" with the advantage of disc brakes.  Although the XJ/MJ D44 drums are larger then the 35.  The axle shafts are .01" larger IIRC and have 1 more spline.  The tubes are a bit larger (i'm not sure about the actual thickness) 3" as opposed to 2.75" but you'll want to have the tubes welded since they are prone to twisting.  You might also want a bearing preload dif cover since the caps have been known to loosen as well.
If you mix and match, you can get Ranger XTL 8.8" with 4.56's but with drums.
Then there is the Toyota 8".  The small trucks have 5 on 4.5" while the Tacomas have 6 on 5.5".  I beleive you can mix and match to get 5 on 4.5" but you'll need to have the disc's drilled for the smaller pattern.  Considering the weight difference and the ease of gear changes, I'd probably consider a Toy 8" if I had to do it over again.
« Reply #5 on: August 23, 2008, 09:14:15 AM »
Go with the '95+ Exploder 8.8 if you don't want to change lug pattern and are going to keep the front axle.
If you're up to upgrading both axles, consider a Waggy front and rear D44, or Waggy front d44 and Isuzu Rodeo/Honda Passport rear d44.  The Isuzu rear axle has disc brakes and same 6-lug wheel pattern as the Waggy front axle.
Benefit of rear AND front d44's is being able to regear lower than 4.88, which the 4banger needs with larger tires.  5.13 and 5.38 are better options for 33" and 35" tires, respectively.
Mr_Random
« Reply #6 on: August 23, 2008, 01:49:10 PM »
I read that some mix (can't remember if it's front or rear) of grand wagoneer springs are the same as YJ's, but don't know about spring perch width. I'm sure if you could find dual waggy 44's you'd be happy about it. There are tons of them around here, still driving and everything, but it's arizona, and anything under 50 years old will probably still run after sitting around for that long, haha.
And yeah, isuzu rodeo 44's are also SUA (pretty sure), can have disks, and commonly come with 4.10.
What I'm thinking for my XJ is pulling another Xj 44, pulling outers from a ZJ for disks, and trying to find a rodeo with 4.56 gears and carrier... At any rate I'd probably end up with two or more 44's and parts floating around.
MJ 44 would be a good find for you guys too...
  • Poseur Extraordinaire®
« Reply #7 on: August 23, 2008, 02:50:56 PM »
Just get D60's....it's 8 lugs or nothing.... :stick:
« Reply #8 on: August 24, 2008, 01:05:24 AM »
Hmmmm. I will be happy to get my front D44 [to match the rear (which was pirated from my sisters Jeep) not to mention I want to go 5.38] and to add OX Lockers!!!
« Reply #9 on: August 24, 2008, 07:36:47 AM »
I'm thinking OX lockers would have been nice....no air lines or compressor to worry about. :'(
« Reply #10 on: August 24, 2008, 08:15:18 AM »
Or save some money and get the best locker with the least number of parts to fail - Detroit Locker.
oldirtydirt
« Reply #11 on: August 24, 2008, 10:11:59 PM »
not sure if i see the advantage of running a detroit locker i have one in my 72 ford and i have a spool in my yj the spool is better on road, it is lighter, it is stronger, and best of all it was $138 delivered to my house my detroit is horrible on road but it does work off road just a thought sorry to be nosey.................P III
« Reply #12 on: August 25, 2008, 12:20:43 AM »
Hmm, my Detroit is pretty quiet and well mannered.
« Reply #13 on: August 25, 2008, 05:50:13 AM »
Spools are pretty hard on axleshafts on the road, you only get so many stretch cycles.  So unless you are running a big 35 spline shaft, I'd make sure to pull and check your shafts occasionally.  D44 sized shafts don't like spools for long on the pavement.
The shafts from my spooled CJ which was driven on the road a lot ;)
« Reply #14 on: August 25, 2008, 06:49:59 AM »
Thats the plan!
