Author Topic: 33x10.50 vs. 33x12.50  (Read 5097 times)
willbacker45
« on: August 21, 2008, 09:51:48 PM »
 :brick: still trying to decide i have a 97 with a auto  :'(
wat should i get?
i dont drive far ever just about 2miles to school everyday and i live in the country so no highways close by...
ive got a 4in. lift
cragar soft 8 rims with 4.75 BS
stock flares cops around here dont care  :weee:
so wat do ya think
Re: 33x10.50 vs. 33x12.50
« Reply #1 on: August 21, 2008, 10:04:30 PM »
I have 33x10.50's and 5" of lift.   With the 2.5L I wouldn't go any larger.  MANY times I out perform our 4.0 counter parts with 33x12.50's.  I like the look of the 10.50's!
« Reply #2 on: August 21, 2008, 10:32:39 PM »
Didn't we go through this already?  I'd choose 33x10.5R15's.  I like the look of the narrower tire.  I run 35x12.5R15's and if I downsized, I'd go with 10.5's to get a similar proportion.  I like tires under the flares, not for Johnny Law but because when the tires pick up crap, it gets flung all over the place.  If you drive in rain, the tires will kick water through your window if you ahppen to leave it open.  If you have a soft top crap will get flung up across the rear side and stain the top.  These are sort of nitpicky but if it's a daily driver, they do become issues that will wear you down.
oldirtydirt
« Reply #3 on: August 21, 2008, 10:36:37 PM »
 :bandit:
willbacker45
« Reply #4 on: August 22, 2008, 04:58:29 AM »
yes we did i just want to make sure i am doing the right thing lol sorry but thanks  :thumb:
« Reply #5 on: August 22, 2008, 05:51:40 AM »
The skinnier tires will gain you somewhat better fuel milage, about 1-2 miles per gallon
« Reply #6 on: August 22, 2008, 08:52:53 AM »
Get the wider tires for more stability off-road.
willbacker45
« Reply #7 on: August 22, 2008, 10:46:10 AM »
you guys also need to remember i have stock gearing and axels  :fitz: so i thinks the 1250 is kinda big
my soft8's stick my bald old 31 1050s out about an inch or two past the fender  so i think i have the stability what do u think?
« Reply #8 on: August 22, 2008, 10:58:24 AM »
You will most likely be fine but more is always safer.
« Reply #9 on: August 22, 2008, 12:41:36 PM »
Just go with the 10.5's.  You're already widening the stance with the wheels over stock.  Since you have stock gearings, the additional weight and rolling resistance will work against you.
« Reply #10 on: August 23, 2008, 05:35:20 AM »
I went from 12.50 to 11.50 tires, same diameter but definite gain in milage. Wheels the same, no change in stability and can still do 45 or better on these nice curves getting on the freeway
willbacker45
« Reply #11 on: August 23, 2008, 01:12:41 PM »
thats exactly what i want a 33x11.50 where did you get them and who makes them? If i could get those i would be very happy  :biggrin:
« Reply #12 on: August 23, 2008, 05:32:03 PM »
I run 32x11.50 goodyear mtr's same exact diameter as cooper stt 33x12.50's. Much better tire also the coopers had a bad habit of chunking on rocks
« Reply #13 on: August 24, 2008, 01:01:10 AM »
I was told that BFG MT's came in 33X10.50 but I haven't been able to find them locally!!!
« Reply #14 on: August 24, 2008, 01:08:59 AM »
American Tires?  I had to order my 34x9.5R15's when I bought it.
