Author Topic: Motor Mounts  (Read 4041 times)
nic99007
Re: Motor Mounts
« Reply #15 on: September 22, 2008, 08:54:30 AM »
i got my stuff from rockauto.com they shipped fast and had great prices.  the switch took about 1 hr.  I wasn't really in any hurry it could have been done faster.
Re: Motor Mounts
« Reply #16 on: September 22, 2008, 10:54:23 AM »
Jeeze, my motor mounts cost $70 - but they are a little beefier than stock ;)
http://browndogindustries.com/c2569-0jeepmotormounts.aspx
I see they now have an ultraflex rubber set for $100, must cut down on the poly vibes
http://browndogindustries.com/cu2569-0motormountsultra-flexrubber.aspx
Re: Motor Mounts
« Reply #17 on: September 22, 2008, 12:24:16 PM »
I had a set of 1" Curries that I made work.  Then I received a free set from TD performance to T&E.  After that I went back to stock mounts with JKS spacers.  The vibrations in a daily driver were a bit annoying to say the least.  Other then the vibrations, the biggest difference was the powertrain torquing when starting off on on a hill.  I'm sure the vibrations while idling didn't help my exhaust any either.  I went through a few exhaust hangers on my Borla.
Re: Motor Mounts
« Reply #18 on: September 22, 2008, 12:33:34 PM »
I might order up the new bushings, they only cost $30 if you bought your MM's before they were available.
Re: Motor Mounts
« Reply #19 on: September 22, 2008, 12:58:26 PM »
I doubt they will be worth it.  MORE had something similar but stopped making them.  I don't think you can have BOTH a solid bushing that also isolates engine vibrations.  If I didn't do any many on road miles as I do, I would have probably kept the poly mounts.
