Author Topic: Motor Mounts  (Read 4040 times)
nic99007
Motor Mounts
« on: September 15, 2008, 03:18:31 PM »
I should have some new motor mounts and a new tranny mount showing up any day now.  I was wondering if anyone had any suggestions or tips on changing them out.  They don't look to be to complex, I just always hope there is an easier way.   :biggrin:
Thanks in advance.
Re: Motor Mounts
« Reply #1 on: September 15, 2008, 03:27:31 PM »
It's pretty easy.  Unbolt the mounts from the frame, put a floor jack under the oil pan, pull the bolts that attach to the block mounts and reverse the process.
For the tranny mount, a jack under the tcase then pull the skidplate.
Re: Motor Mounts
« Reply #2 on: September 15, 2008, 05:09:31 PM »
like oldjeep said it is fairly straight forward... only thing i will add is that in addition to the tranny mount there is a stud that connects to the "torque arm" that has 2 rubber "isolators" that you could also get a new one while you are at it is you are concerned that all the rubber things are shoot. but that stud with rubber isolators isn't too important ( mine is bent pretty good but still does its job as far as i can tell.) so i wouldn't worry about it too much, / just make sure it is in 1 piece when doing the tranny mount.
hopefully this was more useful that confusing.
Got Wood?
Re: Motor Mounts
« Reply #3 on: September 15, 2008, 07:29:56 PM »
I agree, pretty simple and straight forward, the only thing I wanted to add, is I would place a piece of wood on top of the jack before it contacts the oil pan just to distribute the weight a little better.
Re: Motor Mounts
« Reply #4 on: September 16, 2008, 07:43:35 PM »
Just out of curiosity, do you replace mounts only when they are damaged or is this a preventive thing (like change every 100K miles or so)?
Re: Motor Mounts
« Reply #5 on: September 16, 2008, 08:23:03 PM »
I'd replace both while you're at it.  They come as a set anyway.  Better to replace both then to replace one and have the otherside fail soon after.
nic99007
Re: Motor Mounts
« Reply #6 on: September 17, 2008, 08:23:07 AM »
when i looked at mine the rubber around the mounting point is almost all gone and the motor is sagging down close to an inch.  So I thought I should change them.
One more question, does anyone know what amount of torque to use on the new mounting hardware??  I looked in my Haynes manual and it didn't say.  It did say to use some kind of thread lock.
Re: Motor Mounts
« Reply #7 on: September 17, 2008, 12:20:34 PM »
Hmm, never bothered with thread lock compound.  The mount requires only 38lbs-ft while the bolt through the mount requires 51lbs-ft.  The transmission mount is only 40lbs-ft and the skidplate is 65lbs-ft.
nic99007
Re: Motor Mounts
« Reply #8 on: September 17, 2008, 01:00:50 PM »
Jeffy,
Thanks  :beers: I knew that someone on here would know.
nic99007
Re: Motor Mounts
« Reply #9 on: September 19, 2008, 09:54:04 AM »
made the switch yesterday.  All I can say is WOW. My junk feels so much tighter now.  no more suddering as I start out in 1st gear.  my shifter actually holds still while driving.  I wouldn't say it feels more powerfull, but a lot more responsive while accelerating.  best $30 bucks I've spent in a long time.  I would recommend that everyone check thier mounts for signs of wear,
Re: Motor Mounts
« Reply #10 on: September 19, 2008, 11:47:29 AM »
The biggest differe is probably how the torque is applied.  It probably feels more instantanious since you start moving rather then waiting for the powertrain to get the slack out, so to speak.  I've noticed the difference wen going from stock rubber mounts to poly mount even.
Re: Motor Mounts
« Reply #11 on: September 19, 2008, 03:53:16 PM »
How long did the change take you, and how difficult was it?
TrailsLessTaken
Re: Motor Mounts
« Reply #12 on: September 19, 2008, 07:36:29 PM »
I think i did mine in about 45 mins or so. Its pretty easy to do if you have everything you need right there
Re: Motor Mounts
« Reply #13 on: September 21, 2008, 07:04:45 PM »
wow you got a deal. my 1 motor mount cost me $20 at auto zone.
Re: Motor Mounts
« Reply #14 on: September 21, 2008, 07:25:54 PM »
Typically, you'll get all three mounts for around $35.
I buy mine from here since he's a 4banger Mailing List Member.
