Author Topic: Steering Parts  (Read 7062 times)
Re: Steering Parts
« Reply #15 on: October 03, 2008, 05:53:51 PM »
nope...considering where it is and how strong it is, the chances of failure seem pretty low.....and I'm just a poseur anyway... :wave:
How strong what is?  Those TRE's they use are the same thing used on 1/2 ton chevys' from the 70's.
Re: Steering Parts
« Reply #16 on: October 03, 2008, 06:23:13 PM »
Do you carry an extra passenger side TRE on the trail?  One of the 2 problems I've got with the JCR stuff is that they modify an off the shelf TRE for their kit.
Mine is the same way, from PartsMike.  Reverse reamed stabilizer hole.
  • Poseur Extraordinaire®
Re: Steering Parts
« Reply #17 on: October 04, 2008, 05:08:23 AM »
That's where JCR gets theirs......
Re: Steering Parts
« Reply #18 on: October 04, 2008, 05:09:34 AM »
They were used in 3/4 ton as well.  More than enough considering the geometry of their steering and the other parts used.
Oilsmoke
Re: Steering Parts
« Reply #19 on: October 04, 2008, 06:34:01 PM »
Well  I have to Work this weekend So i was in a hurry and I ordered the Stock parts just 30  minutess before Jeffy Posted the Info. I wanted the Rugged Ridge Setup. So I tried to cancel my Order and they Had it Shipped out of Denver. Damm that was fast.  I sure it will cost me shipping back so I quess I am Stuck with it.  :mad: It should be here Monday Though.
Thanks Guys for are the Great Imput. I wish I could of used it.
Oilsmoke
Re: Steering Parts
« Reply #20 on: October 07, 2008, 07:42:01 PM »
Stock long TRE and small end Install So the loosenest Is gone and I will install the drag link this friday when i am Off work.
The Stock replacement parts will work Great for My Needs. nice to feel a tight one agian. :hitit:
Re: Steering Parts
« Reply #21 on: October 08, 2008, 09:46:20 AM »
There's a pair of WJ knuckles on a local board for $100 if anybody is looking to highsteer a d30.
Re: Steering Parts
« Reply #22 on: October 08, 2008, 10:22:31 AM »
Once you do all the custom work isn't it cheaper to just buy the teraflex knuckle that just bolts on?
Re: Steering Parts
« Reply #23 on: October 08, 2008, 12:30:45 PM »
Does the WJ knuckle raise the tie bar and drag link or just the drag link?  I recently saw that Teraflex offers a tie rod flip kit also that will raise the tie rod but I don't think it would work with an SOA (for those who have SOA in front).
Re: Steering Parts
« Reply #24 on: October 08, 2008, 12:53:48 PM »
It raises the drag-link.  Although you can retap the knuckles so you can then mount the tie-rod ontop of the knuckles.  Which may or may not interfere with the leaf pack on a SOA.
« Last Edit: October 08, 2008, 12:54:41 PM by Jeffy »
Re: Steering Parts
« Reply #25 on: October 08, 2008, 01:14:32 PM »
For an SUA jeep (YJ) it almost seems better (simplicity and cost) to just do the flip and continue to use an inverted T steering setup.  On my YJ it looks like it would be a tight fit with the wheel, I keep thinking 16" rims might be needed.
Re: Steering Parts
« Reply #26 on: October 08, 2008, 01:31:12 PM »
IIRC, if you want to do the whole WJ swap with the two pot brakes, then going with larger wheels might not be a bad idea.  17" seem to be more common with the more extreme rockcrawlers out here.
Re: Steering Parts
« Reply #27 on: October 08, 2008, 01:44:28 PM »
These are good projects.  Thanks for the ideas.
Re: Steering Parts
« Reply #28 on: October 08, 2008, 02:06:47 PM »
True...that's why I run 17's.....
 :whistle:
Re: Steering Parts
« Reply #29 on: October 08, 2008, 03:00:23 PM »
 :whistle:
I thought you did it so you could add spinners later on... :stick: :guns:
