Author Topic: Wideband o2 sensor  (Read 3021 times)
Wideband o2 sensor
« on: October 09, 2008, 10:14:44 PM »
Anybody here used a wideband o2 sensor on their jeep?  What results did you get and how helpful is it in tuning the jeep?
Re: Wideband o2 sensor
« Reply #1 on: October 14, 2008, 10:44:26 AM »
Nobody has used one?
95yj4
« Reply #2 on: October 14, 2008, 12:03:12 PM »
I'd like to know the results, too. What would u even use to run the wideband, Megasquirt? Or somethin else?
« Reply #3 on: October 14, 2008, 05:31:26 PM »
Kits range from $200-$300 that have their own guage, sensor, and bung.
« Reply #4 on: October 14, 2008, 06:29:46 PM »
Anyone running a turbo or supercharger will be running a wide band O2.  They are used for diagnostics and allow for one to fine tune their engine, especially when running a FMU.  You can use them with just a bar gauge so you know if your engine's running lean/rich.  Nothing to mystical about them.  Really though, you need to be doing something drastic for the PCM not to be able to adjust on it's own.
« Last Edit: October 14, 2008, 06:30:28 PM by Jeffy »
« Reply #5 on: October 14, 2008, 07:39:19 PM »
We're setting one up shortly on my buddy's drag car (Nova) so I'd be interested as well.
« Reply #6 on: October 14, 2008, 09:58:36 PM »
I don't have a FMU but plan on running a wideband o2 to see if any adjustments are needed after all the mods.  I'll probably finish the adj. MAP if the timing needs tweaked.
I've got a:
Mopar Performance cam
62mm TB and spacer
Airtube and K&N
Ford v8 injectors
Taurus fan
Borla header
FirePower ignition kit
95yj4
« Reply #7 on: October 14, 2008, 11:19:59 PM »
If your not running a FMU then what good is it? Dont u need the FMU so u can make the adjustments you need? If not how else r u going about it?
« Reply #8 on: October 14, 2008, 11:44:16 PM »
He'd be able to control it a little by using the adj. MAP.  Timing would need to be adjusted by moving the CPS a little.
