Author Topic: Backspacing  (Read 3297 times)
dledle 16
Backspacing
« on: November 19, 2005, 04:52:56 AM »
I wish to put tires 31/10.5 15 on my tj 1997.
Which is the offset of my origin rims?
Must I change my rims, to avoid frictions and to cross the axles more easily, in off road?
I waits a 3" full traction kit. I research efficacity, but a minimal width. Which is the best compromise?
Thank you,                    Pascal.
Backspacing
« Reply #1 on: November 19, 2005, 11:53:11 AM »
The backspacing is 5.5".  You can put a 31/10.5R15 on there with minor rubbing at full lock and compression.
StefanBidi
Backspacing
« Reply #2 on: November 19, 2005, 12:22:49 PM »
I have 31x10.5" BFG A/T's on factory wheels in my TJ and have some serious rubbing at full lock.  I blame it mostly on the fact that I'm running 15x8" instead of the regular 15x7".  I also did not want to go too wide, so that's why I stuck with factory rims, but from the looks of it I'm going to need to go back to the 15x7's as soon as I get new tires.  In short, I think you'll be fine with the 15x7" factory wheels, you'll just need to adjust your steering stops a little and the downside is that you're turning radius decreases slightly.
Backspacing
« Reply #3 on: November 19, 2005, 12:43:28 PM »
Quote from: "StefanBidi"
Stock wheels for a 2.5L are 15x6" with 15x7" as an option.
dledle 16
Backspacing
« Reply #4 on: November 20, 2005, 04:35:59 AM »
Thank you for your useful informations.
I initially will install the lift kit of 3". Then I would carry out a test with the spare wheel (rim of origin 15x7 already equipped with a tire brigestone DUELER MT673 31/10.5).
Thank you. (France (Cognac))
