Author Topic: Diff Oil  (Read 3865 times)
Re: Diff Oil
« Reply #15 on: November 28, 2008, 10:26:35 AM »
Just pulled the rear cover off....sticky, gooey, black mess....oil really needed to be changed.  Will fill it with a 1/2 gallon of synthetic and see if that fixes the problem...also will look for that drain hole.
Gear oil is some nasty stuff.
Are you gonna do the front end too?
Don't forget to blast a can of brake cleaner in there to wash the gunk off everything.
Re: Diff Oil
« Reply #16 on: November 28, 2008, 12:36:41 PM »
Be sure to rub some on your clothes...   :pirate:
Re: Diff Oil
« Reply #17 on: November 28, 2008, 01:32:43 PM »
A little behind each ear makes the ladies go crazy! :fish:
The first time I changed the gear oil, it wasn't the gear oil that I had problems with. It was the black RTV I used. It took forever to get that stuff off of my hands, clothes,tools.
  • Poseur Extraordinaire®
Re: Diff Oil
« Reply #18 on: December 02, 2008, 07:31:50 AM »
UPDATE:
Changed the front oil as well on Saturday.....have been running in 4WD for the most part over the past two days because of the snow and haven't had any leaks or sputtering out of the vent tubes.
My guess is that the yucky thick oil was thick enough to block the tubes when splattered up there causing it to blow out.....but I really don't know anything.... :'(
Re: Diff Oil
« Reply #19 on: December 02, 2008, 07:46:17 AM »
Kind of weird, my kids comanche just started doing the same thing.  His 8.8 is burping oil out the vent everytime it gets parked in the garage.  Lube isn't even hot coming out of the vent.
Re: Diff Oil
« Reply #20 on: December 02, 2008, 01:01:01 PM »
One thing I did notice...the left over brand new oil in the plastic quart bottle was working it's way out of the cap....I'm starting to believe it has something to do with the cold weather suddenly hitting.
Tsd
Re: Diff Oil
« Reply #21 on: December 02, 2008, 01:39:10 PM »
May there is an expansion-retraction reaction from metals due to the cold weather. Could it be metal seal retracting?  :confused:
