Author Topic: Slave Cylinder leak  (Read 4181 times)
oldewing
Slave Cylinder leak
« on: November 26, 2005, 08:17:18 PM »
Hi all,
   Just found this site.  I have a 91 YJ, 2.5, 175,000 miles. I bought it new in 90. I have replaced the slave  3 times and it is leaking again.
Help me ..... is there a fix.
Slave Cylinder leak
« Reply #1 on: November 26, 2005, 09:06:55 PM »
You can always swap to a earlier or later model bellhousing and external slave.  XJ's from 1984-87 (might be longer) have external slaves.  The AX-5 on the YJ didn't get an external slave till 1994.
oldewing
Slave Cylinder leak
« Reply #2 on: November 27, 2005, 05:20:44 AM »
Thx's Jeffy, I will look about for another bell housing.  Do you know if the trans behind the 4.0 will swap over?  I have a 94 doner Jeep on the way to the house.  Big Engine fire.  It has a hard top and some other things I am interested in.  Its the 6 with a 5 speed.
Slave Cylinder leak
« Reply #3 on: November 27, 2005, 01:54:37 PM »
You will need a bellhousing from a Dodge Dakota 2.5L.  They used the 2.5L and the AX-15. You will also need to swap the input shaft for the transfer case from 21 to 23 spline but you can take it from the donor.
oldewing
Slave Cylinder leak
« Reply #4 on: November 28, 2005, 05:12:46 PM »
:D  :D Thanks Jeffy, I will go a lookin for a bell  housing.
jeepsohigh
Slave Cylinder leak
« Reply #5 on: December 15, 2005, 07:47:46 PM »
I dont know if you ever did this but here is some info from a member of my Jeep club that did this swap.
http://www.midwestjeepthing.com/Forums/Topic.asp?topic_id=22066&forum_id=17&Topic_Title=AX%252D15%2Bswap%2BTech%2BWrite%2Bup&forum_title=General+Technical+Forum
jwrape
Slave Cylinder leak
« Reply #6 on: December 16, 2005, 05:23:26 AM »
I have done the AX5 to AX15 swap myself and I am actually getting all the parts together as I write to do another swap on my Dad's Jeep. It is fairly easy and well worth the upgrade if you plan to keep your Jeep for a while.
I learned how to do the conversion from the original guy that figured it out here on Pirate 4x4
http://www.pirate4x4.com/forum/showthread.php?t=181361&page=6&pp=25&highlight=ax-5+swap
Jeremy is a nice and guy and I am actually buying the conversion he originally did on his 2.5L for my Dad's Jeep.
Slave Cylinder leak
« Reply #7 on: December 16, 2005, 12:42:06 PM »
An extensive parts list and pictures would be appreciated, jwrape. :D
One thing that I wonder about is why go with the AX-15 when you can do a NV3550 and have enough strength for a 5.2L.  I'm pretty sure no one had done one yet but I've seen a few AX-15 to NV3550 swaps.  Uses the same bellhousing too.
