Author Topic: homemade air intake  (Read 2044 times)
andrew383
homemade air intake
« on: December 06, 2008, 09:52:23 PM »
whats up guys.. im gonna fab up my own air intake using the factory box.i need some advice first tho.im gonna get the 62mm tb as well so i was thinkin about going with 2.5" or 3" piping.62mm is just under 2.5" so i dont wanna go to big.
so how big should i go to keep from losing power?
Re: homemade air intake
« Reply #1 on: December 07, 2008, 09:22:03 AM »
Measure where the tube goes into the TB. Whatever that measurement is that's what I would go with.
« Reply #2 on: December 07, 2008, 01:04:49 PM »
I've found it easiest to use a 4.0L intake tube, takes out all the hassle.  Nice smooth tube and doesn't have the chambers the 2.5L does.
« Reply #3 on: December 07, 2008, 06:54:59 PM »
I thought the 2.5 and 4.0 TB had the same size intake hole (where the air intake is). When I went from the 2.5L TB to the 4.0 my rockit city air tube fit both with no problems.
Are they the same size?
« Reply #4 on: December 07, 2008, 07:21:32 PM »
OD vs. ID  OD is the same.  That's what the intake relies on.
« Last Edit: December 07, 2008, 07:22:21 PM by Jeffy »
andrew383
« Reply #5 on: December 07, 2008, 07:34:59 PM »
well 62mm is roughly 2.47 inches so i was thinkin 2.75" tubing.looking at all the parts ill need i think i can built it for about $100.  :nod:
andrew383
« Reply #6 on: December 16, 2008, 06:19:12 PM »
hey guys can someone measure the outlet at the air box? it looks like 3in but i wanna be sure.im gonna order the stuff this week so its waiting for me at home  :weee:
