Author Topic: Is 62mm TB too much for the 2.5??  (Read 8347 times)
jwrape
« Reply #15 on: December 22, 2005, 12:28:18 PM »
Quote from: "Jeffy"
Stock 2.5L is around 45mm's while a 4.0L is around 54mm.
That's still a major difference. I am gonna get some more drimel bits and bore out the spacer and the TB. I did a little boring on the intake already.
Note: Made sure no shavings got into the intake and motor. I am Crazy but not stupid. LOL!
« Reply #16 on: December 22, 2005, 12:33:33 PM »
I still haven't bothered matching the port opening.
jwrape
« Reply #17 on: December 23, 2005, 05:48:51 AM »
Quote from: "Jeffy"
What all have you done to you 4banger? Just curious. You don't have anything listed in your signature.
« Reply #18 on: December 23, 2005, 01:33:01 PM »
Nothing internal other then taking care of it.  PD Ignition gapped at .060". Performance Carsound Cat-back, Borla Exhaust.  Went back to the stock airbox and Fram Filter.  4.0L TB and a 1" Poweraid Spacer.  This has tuned the powerband a bit higher but still gives me decent power in the mid to high range.  I could have opened up the exhaust more to allow for more top end but then I lose low-end.  It's all about tuning for what you want and not just slapping parts on.  Hard part it knowing where it's going to change things.
I probably should have kept my .440 cam but since I moved to a Emissions state, I didn't want to risk it.
