Author Topic: Is 62mm TB too much for the 2.5??  (Read 6783 times)
Dont Know Squat
« on: December 06, 2005, 01:30:28 PM »
I did a search and couldnt find a lot on this. so I am looking to swap the T.B and add a spacer. Is a 62 mm to much ? I have a pretty stock 2.5 with the exception of a "cold air" intake and a highflow cat and dynomax exhaust..anyone done this on the 2.5?
« Reply #1 on: December 06, 2005, 01:39:56 PM »
I do not recommend going with a 62mm unless you plan on doing a lot of other work.  It's too much air for the stock setup and you'll run into problems.  Not to mention if you're planning on buying a 62mm TB, you'd be better off saving your money and going with a stock 4.0L tb for a fraction of the cost.
Dont Know Squat
« Reply #2 on: December 06, 2005, 02:02:57 PM »
thanks jeffy. so what other stuff would need to be done just for conversation sake? hotter spark? different injectors? cam? would it be about like running a carb with too much cfm?
SMC4WD
« Reply #3 on: December 06, 2005, 04:20:35 PM »
I'm running a 4.0L that has been bored out.   I don't remember what is was bored out to, it was just shy of what Rubicon does.
I got my from your buddy (Jeffy), James at Jeepers Creepers in S.F.
I opened the factory box, removed the reducer tubes with a K&N air filter.  I'm running an AiRaid poweraid TB spacer and a Turbo City MAP sensor.
As said before...   Teeny bit here and there adds up.
« Reply #4 on: December 06, 2005, 04:39:34 PM »
I think you could get away with it but at a minimum would want an Adj. MAP sensor to dial in your air/fuel ratio.  Then a FirePower ignition setup to make sure all the extra fuel is well burnt.  Index the plugs while you're at it ;)
SMC4WD
« Reply #5 on: December 06, 2005, 05:10:31 PM »
Ya, Ya...
MSD Ignition with blaster coil and Moroso 8mm wires too!   :lol:
« Reply #6 on: December 06, 2005, 06:55:25 PM »
Quote from: "SMC4WD"
Hmm, I'm not sure if I know him.  Did he say he knows me?
SMC4WD
« Reply #7 on: December 07, 2005, 09:22:34 AM »
Quote from: "Jeffy"
No...  But since he's in S.F. and you're in the No Cal area somewhere, I had to figure you've heard of him.  His name is James and a guy named Shaun works there too.
He runs a business that's mostly internet.  Primarily caters to TJ's.  I picked up a custom dual battery setup from him, and that bored out TB.  Really a great guy to deal with and talk to.
Check him out sometime.
(Shameless plug here:)
http://www.jeepersandcreepers.com/
« Reply #8 on: December 07, 2005, 01:40:50 PM »
Oh, a TJ'er.  I don't associate them them people.   :wink:
jeepfourlow
« Reply #9 on: December 07, 2005, 02:11:58 PM »
YJ PRIDE
SMC4WD
« Reply #10 on: December 07, 2005, 04:30:14 PM »
I own a YJ too...
There's something to be said about square headlights!!
Although if I could do it all over again....    Hummm...
« Reply #11 on: December 08, 2005, 10:56:47 PM »
Hi Guys, We got a few emails concerning the 4.0L throttle body on a 2.5L and I can tell you the 60mm is more then enough for the 2.5L We have had a few people try out the 62mm on the 2.5L and they did not gain any performance but wound up getting a few check engine codes.
We do bore out the 2.5L throttle bodies to 60mm and this will save you from having to purchase a 4.0L throttle body. We no longer bore the stock throttle bodies to 62mm due to cracking of the base. If you really feel you need 62mm, I would recommend a re-designed throttle body and not the stock one because the wall on the stock throttle body tends to get weak and if you add a after market air filter kit with hose, they tend to stress the throttle body and may cause it to crack.
Here's an older link on a bored out throttle body on a 2.5L http://www.gottrail.com/TJ/4.0TB.html
PS: We like YJs and all the other cool Jeeps out there (previous square headlight Wagoneer owner)  :wink:
« Reply #12 on: December 08, 2005, 11:05:05 PM »
I doubt a 2.5L could really see much gain over 54mm without boring out the intake.
Not much wheeling in SF... :wink:
jwrape
« Reply #13 on: December 22, 2005, 06:53:10 AM »
Quote from: "Jeffy"
Not sure what the stock measurements of the 2.5L TB and the 4.0 TB are but I know when I put the 4.0 TB on, it really made a nice difference in low and RPM rev up. It is one of the best upgrades that I have done.
« Reply #14 on: December 22, 2005, 11:39:18 AM »
Stock 2.5L is around 45mm's while a 4.0L is around 54mm.
