Author Topic: quick tire question  (Read 2075 times)
tallrugbyguy
quick tire question
« on: January 13, 2009, 06:47:39 PM »
i currently have  215 75 15 on my jeep.
i am wondering if a set of 235 75 15 will fit?
also what is stock tire size?
95 yj
thx guys
jason 00 tj
Re: quick tire question
« Reply #1 on: January 13, 2009, 07:15:55 PM »
yes they should fit. a friend of mine was able to fit 31's with all stock suspension and a 235 75 r15 is about 30inches tall so you should be good.
I'm pretty sure 215 75 15 is stock tire size witch is about 27 inches tall.
« Reply #2 on: January 13, 2009, 07:22:30 PM »
It might be close without a bit of lift. Mine came with 205/75/15's :roflol:
« Reply #3 on: January 13, 2009, 08:21:05 PM »
Stock are usually 205.75R15's or 225.75R15's.
Stock wheels will usually be 9-slot 15x6 or spoked 15x7.
« Reply #4 on: January 13, 2009, 08:22:54 PM »
They'll fit, but will rub with a little bit of axle articulation like a ramp into a parking lot.  Will also rub in the rear with rear passengers.
rubberducky
« Reply #5 on: March 24, 2009, 10:23:05 AM »
Had 31-9.5's no rub at all. on stock springs. Then added 2 inch lift and run 33-12.5 and they don't rub with the wheel spacers.
« Reply #6 on: March 24, 2009, 12:37:09 PM »
My YJ came with 31 10.5 and stock springs, and it rubbed with any kind of articulation or if I let 2 people in the back...
