Author Topic: Re: JKS Budget Motor Mounts  (Read 4199 times)
Crunch
« Reply #15 on: January 21, 2009, 06:38:49 PM »
I have a 99 TJ and want to put in a 1" motor lift. So there the same as a 4.0 L ?
As Jeffy indicated, yep, they are the same.
can you do motor mount lift without a body lift?
I seriously doubt it.  I don't see how you'd get the fan lined up.
:crap: ...I was thinking about trying to go with the Rough Country 4" and using a 1MML" to get away without the t-case drop.  5" is more lift than I want... I think  ???  Thanks.
At 4", you will need either the TC drop or the SYE.  A MML alone will not reduce the rear driveline angles nor improve the spline contact on the slipyoke.
I disagree, yes it actually does/can.  Moving the motor up 1" and the Tranfer case up an inch worked perfectly on my setup.
From experience, whether or not you can just remove the t-case drop with a MML and BL is based on a couple of solid factors and then on some ambiguous ones. Your engine, transmission, t/case, and rear diff are the solid factors. If you have a 2.5L, AX-5, NP231, and a D35,  you have the longest rear driveshaft available in a TJ.  A good friend has a 4.0L, AX-15, NP231, D35 with a 1"MML and BL, RE non adjustable lowers and stock uppers in the rear (no TC drop). He has 4.5" of lift and no t/case skid plate drop and has very little vibes, so little infact that he could probably eliminate them with a cam bolt kit.
That said, now for the ambigous part, I've known jeepers that had vibes with the same drivetrain combo as his and as mine and the only way they could resolve them was with a t/case drop or SYE and adjustable upper and lower CAs.  I even know one guy that had to use cam bolts also. I think it all depends on what day of the week you Jeep was assembled on.
Worst case, you now have a 1" Body lift + MML, and have to put the TC back on until you can get an SYE and possibly adjustable CAs.  You could also always use washers instead of the TC drop parts to adjust the amount of drop if you have vibes.  Maybe you can get by with .5"?
FYI, the 5+ inches I got from my Rough Country kit and Body lift allowed me to clear 35's easily (well...I did a little fender flare trimming, as I have 10" wide wheels and a lot of backspacing, and my tires would rub the edges of the flares fully compressed)  I ran 33's on this setup for years, and it looked fine.  This was my budget approach to removing the TC drop.  I still plan to get an SYE, but it moved further down the list.  I'll do it when I get a new flat skid.
Well, if it's not a daily driver adn you don't mine the vibrations, (it's like you're sitting in a massage chair) then I'd consider getting poly enging mounts rather tehn going with the spacers.
I'd probably look at these: http://browndogindustries.com/
I have a Daystar Poly MML and the vibes they pass to the body are HORRIBLE.  I should have went with M.O.R.E. bullet proof MML.  The other Jeepers here swear by them, and have little to no vibes from them.
http://www.northridge4x4.com/proddetail.php?prod=MORE-JM600L
My $0.02.  Good luck
