Author Topic: Re: JKS Budget Motor Mounts  (Read 4198 times)
99tj
« on: January 15, 2009, 09:07:49 AM »
I have a 99 TJ and want to put in a 1" motor lift. So there the same as a 4.0 L ?
Re: Re: JKS Budget Motor Mounts
« Reply #1 on: January 15, 2009, 12:12:52 PM »
Yes, they will work without the extra work of having to drill out any studs.
« Reply #2 on: January 16, 2009, 02:13:31 AM »
Have you seen these slick new motor mounts? http://browndogindustries.com/cu2569-11mmlultra-flexrubber.aspx
TrailsLessTaken
« Reply #3 on: January 16, 2009, 08:40:19 AM »
i found these a few months ago and though about getting some since i have a 1" body lift to lift everything up another inch.  Whatever happens though its waiting till spring time so I can work in the garage without freezing. It was -17 when I left for work this morning
« Reply #4 on: January 16, 2009, 11:35:29 AM »
can you do motor mount lift without a body lift?
99tj
JKS Motor mounts
« Reply #5 on: January 16, 2009, 01:31:32 PM »
I have a 99 TJ and want a 1" lift for my motor. Is the mount I order the same as a 4 L ?
Re: JKS Motor mounts
« Reply #6 on: January 16, 2009, 01:48:36 PM »
TJ's use 4.0L mounts for both engines.
I've had a few different MM's and if it's a daily driver I recommend the spacers.  For daily driving the vibrations really get to you after a while.  Also, I suspect this may have been the case of the demise of my exhaust.
The other situation I notice a big difference is when launching from a stop.  I can feel how soft the OEM mounts are as the engine torque's to one side.  Launches aren't nearly as positive.
99tj
« Reply #7 on: January 16, 2009, 04:12:04 PM »
Thanks for the info! It hasn't been a daily driver in a couple years now. Do you know where i can get these. Living in Canada i know i will have to order them from the States.
99tj
« Reply #8 on: January 16, 2009, 04:16:32 PM »
Those are nice! 8)I"ll have to check them out.
« Reply #9 on: January 16, 2009, 04:29:48 PM »
Well, if it's not a daily driver adn you don't mine the vibrations, (it's like you're sitting in a massage chair) then I'd consider getting poly enging mounts rather tehn going with the spacers.
I'd probably look at these: http://browndogindustries.com/
jwalls4x4
« Reply #10 on: January 16, 2009, 06:19:47 PM »
X2?
« Reply #11 on: January 17, 2009, 01:57:31 AM »
I wouldn't try a 1" MML without a 1" BL, you'll run into clearance issues at the tranny cover and between the airtube and brake booster.  It also helps keep the fan lined up if you're still running a mechanical fan.
jwalls4x4
« Reply #12 on: January 17, 2009, 07:14:41 PM »
 :crap: ...I was thinking about trying to go with the Rough Country 4" and using a 1MML" to get away without the t-case drop.  5" is more lift than I want... I think  ???  Thanks.
« Reply #13 on: January 17, 2009, 07:32:11 PM »
At 4", you will need either the TC drop or the SYE.  A MML alone will not reduce the rear driveline angles nor improve the spline contact on the slipyoke.
TrailsLessTaken
« Reply #14 on: January 18, 2009, 07:52:20 PM »
I would spend the extra money and do the SYE.  I wish I would have done it in the first place, would have saved me a few u-joints, mufflers and transfer case parts.
