Author Topic: Still some vibs after OME + t-case drop  (Read 4264 times)
01amberfirewv
« on: December 09, 2005, 06:03:36 AM »
has anyone else experinced this?  Is there anything else I should check.  I installed the trackbar relocator and had an alignment.  The vibes usualy come in somewhere between 25 and 35k.  I plan on installing a M.O.R.E BL and an MML in the spring and I gues I will live with the vibs until then if I have too
SMC4WD
« Reply #1 on: December 09, 2005, 02:38:35 PM »
Some vehicles, and it depends entirely on the vehicle will vibrate after even the smallest of lifts.
I would recommend checking out the rear pinion angles, but if your going to do more with the motor mount lift it may be 'putting the cart before the horse'.
Do all the suspension work that you plan on doing (for a while), then check out your angles.  At least it'll save you the efforts of correcting it all, then having to do it again.
« Reply #2 on: December 09, 2005, 09:46:00 PM »
It's most likely the driveshaft angle.  If you do the engine list, it should fix it.  You could also get cam'ed bolts that will allow you to adjust the pinion angle a bit.
