Author Topic: Cleaning injectors  (Read 1913 times)
Bikerjr1
Cleaning injectors
« on: February 08, 2009, 09:36:31 AM »
My brother-in-law brought me 5 19# mustang injectors from his dealer, they have been sitting around awhile and need to be cleaned. They were working when pulled.  The question that I have is what is the best thing to soak and clean them with.  Some parts cleaners say not to soak rubber or plastic parts, B12 is one of them.  I thought about Seafoam, the label doesn't say anything about rubber or plastic.  I'm worried about the inside of the injector being gummed up.
thanks,
JR
Re: Cleaning injectors
« Reply #1 on: February 08, 2009, 10:51:57 AM »
http://www.cruzinperformance.com/fuelinj.html
And the benefit of sending more than 4 injectors, you can use the 4 closely matched injectors for even performance.
Bikerjr1
« Reply #2 on: February 09, 2009, 08:27:02 AM »
Thanks, but I was really looking for some way to clean them myself.
JR
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
« Reply #3 on: February 13, 2009, 09:14:15 AM »
Try NAPA Echlin "pro clean" part #CRB218489. The injectors have to be in the Jeep and running if you use this product.
« Reply #4 on: February 13, 2009, 01:41:26 PM »
I'd use Seafoam.  Then you can treat everything.
