Author Topic: Matching Paint for the Jeep  (Read 2341 times)
« on: February 10, 2009, 09:28:09 AM »
Hey, guys, where would I find the paint code for my Jeep, and where could I buy matchingpaint for some touch ups?  My paint is peeling in some places (my Jeep has some cheap paint job that is now peeling; God only knows what the PO did to it!), and I want to touch it up to avoid rust (I really dont care if it does not look perfect; good enough is fine as long as it does not stick out like a sore thumb and prevents rusting).
Re: Matching Paint for the Jeep
« Reply #1 on: February 10, 2009, 11:56:16 AM »
You want to look for the ID tag on the firewall behind the brake boster.  IIRC, it's a 4 digit code.  Usually 2 letters followed by two numbers.
Also, keep in mind that unless they are able to take samples and of the Jeeps actual paint, it probably won't match 100%.  Most automotive paint shops can mix you a small batch and then get it to the prefect tone.
« Last Edit: February 10, 2009, 12:42:07 PM by Jeffy »
Offline dexetr30
  • 4BangerJP.comŪ Donator
  • Aloha Mr. Hand!
« Reply #2 on: February 10, 2009, 05:22:09 PM »
This link should give you everything you need as far as where the paint code is located.
http://www.automotivetouchup.com/paint-codes/jeep.htm
You can also buy your paint from them.
« Reply #3 on: February 12, 2009, 01:06:16 PM »
So what would be my paint code?  PG5?  There is not PNT code prior to any other code, so it is not like the site...
« Last Edit: February 12, 2009, 01:06:58 PM by jfrabat »
« Reply #4 on: February 12, 2009, 03:34:14 PM »
Yes, PG5 is for Hunter Green Metallic.
Which could also be found; http://4bangerjp.com/forums/index.php?topic=438
« Reply #5 on: February 12, 2009, 04:14:19 PM »
That's what I thought; just wanted to confirm before I ordered, as neither NAPA nor Advancd Autoparts has that color in stock...  Thanks!
Offline dexetr30
  • Aloha Mr. Hand!
« Reply #6 on: February 13, 2009, 08:56:42 AM »
